Old 05-07-2004, 08:32 PM   #1
76bonanza
76bonanza's Avatar
Plug gap
I am running ngks and just installed a new MSD HEI.
I was running .045 gap is there any reason to run a larger gap or will there be little dif? Daily driver not racer.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-07-2004, 09:04 PM   #2
low 84
low 84's Avatar
what does msd recomend you gap them at with that setup? more powerful spark lets you run a bigger gap which gives you better combustion.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
