05-12-2004, 02:49 PM | #1 |
could somebody walk me thru setting up lifters?
vavle cover was leaking bad so when apart I thought i'd set them up due to some lifter noise.......slight ticking which gets quieter when warm.Does each cylinder have to be at the top of the stroke?Is there any order? any and all help would be great thanks
05-12-2004, 02:52 PM | #2 |
Hydraulic lifters need to be adjusted with the engine running. You adjust by the sound. You need to cut up an old valve cover to allow you to do this without spilling all the oil everywhere.
72 Cheyenne Super 4x4 SWB |
05-12-2004, 05:00 PM | #3 |
Check out this post .
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-13-2004, 02:49 PM | #4 |
Keepin' It Stock
The best method I've ever used to adjust lifters is the one recommended by Century Performance Center. I've used it a couple of times now on different engines and it's always produces perfect results. The instructions and an explanation of the procedure are in a tech article on their web site.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
05-13-2004, 03:30 PM | #5 |
a running adjustment is not the best way to do it. the best way to do it is as follows when the intake starts to open adjust the exahust on that cylinder and when the exhaust valve starts to close adjust the intake on that cylinder
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-14-2004, 03:30 PM | #6 |
I've found that the directions given in most shop manuals are very easy to follow. The ones I have are printed by Hayes. I have one for my truck, and one for my engine (which is a '98 with a roller cam and adjusts the exact same way).
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
05-14-2004, 03:51 PM | #7 |
I have done them many ways, engine running and followed by the mess of oil splattering all over, follow book, but the easiest and best way I have found is to bring the lifter down all the way either loosen or tighten till the pushrod just starts to have resistance then tighten 1/2 turn and then move on to the next one. JMO
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
