who can make me a ....
who can make me an air bag plate. well the set that goes on the crossmember not the one on the lower control arm. and keep in mind that im useing an xmember off a 73-up c-10 dont know exactly the year but my truck is a 67 c-10. if so how much and how much to ship to 79835
Thanx Zef ![]() |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I have a spare set I can send you for $75. They look like this:
![]() Not painted though....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 05-14-2004 at 12:32 PM. |
![]() Join Date: Feb 2003
www.***************** $59.99
blood type; Retumbo
Captkaos, is that upside down in pic? how does it mount excactly?
I have a x-member from a '80 C10 & want to do the same thing. what would be the x-member ground cleareance be with stock components & at 5.5" bag height?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card Last edited by 68C15; 05-14-2004 at 09:59 PM. Reason: I just can't type |
68C15
They way it is pictured is exactly how it will be mounted in the truck. The top piece bolts to the crossmember where the spring pocket goes and the bottom piece sits in the lower control arm spring pocket. From memory, the ground clearance (control arm to ground) would be around 4-5", but I don't remember for sure. I set those pictured up for a 5.5" ride height on a Firestone bag, and wanted it as low as a 5" drop at ride height.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
