05-15-2004, 10:49 PM | #1 |
its just $$$$$
one piece glass
do any of you guys know if the one piece glass kit for a truck will work on a blazer. has anyone seen it done? or know of any information? Pics would be awesome if you have them.
05-16-2004, 10:06 AM | #2 |
Should work. Blazer doors are just Truck doors with the top window frame cut off. Thats all that GM did. The glass is the same.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
05-16-2004, 10:39 AM | #3 |
Don't quote me, but it seems like I read somewhere that you couldn't use the one piece kit on a blazer because of the lack of support for the window glass. The portion of the frame at the back of the door that a truck has, but a blazer doesn't, works as a guide and stabalizer for the window glass. Without it, but glass becomes very unstable until it reaches the top where it will engage the front door framework.
05-16-2004, 07:48 PM | #4 |
I am a Gov't Mule
Goose has a point there, but I would think that with the top on there would be enough support since the rear part of the window frame is molded into the top. And if the tops off, there's no reason to have the windows up anyhow. Just my 1 and a half cents worth
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy... |
05-18-2004, 07:24 AM | #5 |
PROJECT 7DEUCE
That is correct I was asking about the 1-pc glass in my blazer and it will not work the glass will fall out the back of the door because there is nothing to supprt the back of the glass..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-18-2004, 11:50 PM | #6 |
its just $$$$$
it seems like it would work fine with the top on, and with the top off I would never have the window up. But it is an expensive kit to buy, if I only "think" that it will work. thanks for the input guys, I'll keep you posted if I decide to try it.
