![]() Join Date: May 2002
Whistle for TDC
I think I read something about a device which screws into the #1 plug hole
and it makes a whistling noise as air is being forced out of the cylinder as you turn the crank by hand. It supposedly changes pitch the instant air stops being pushed out of the cylinder to air being sucked into the cylinder. Such as when you pass TDC with both valves closed. It was supposed to be very accurate. But, I can't remember where I heard about this device. Anybody ever heard about this thing or know where you can get it? Jim Mt Juliet ![]() |
I seen something on them a few years back, you might try JC Whitney, they seem to have the off the wall stuff. You can always have someone bump the ignition while placing a finger or thumb over the number one. You should be able to feel the air push out and that will be top.dead.center. Good luck. Jay
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
Eastwood...
carries this type of TDC "finder" (Item # 46048). Purchased two years ago and have used it on 3 engine rebuilds to determine TDC when timing/tuning. Works great and will continue to use on future rebuilds and tuneups. Cost is around $23.00 (dual thread pattern of 14mm and 18mm and a 22" attached hose). Additionally, they also sell a 14mm "long reach" extension for about $5.00.
Hope this helps! Thanks...7T1BURB Last edited by 7T1BURB; 05-16-2004 at 11:34 AM. |
blood type; Retumbo
if you have a Cornwell dealer in your area they sell them. bought one a few years ago & use it a lot. dont remember $ but whatever it is it is well worth it.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
