05-19-2004, 10:28 PM | #1 |
14B FF questions
I'm looking for a 14 B FF for my '72. Is there any that will bolt in without having to move the spring perches? I've got a one in a '79 4x4 but the perches are wider on that one by a couple of inches. Give me some info if you can.
Thanks, Matthew
GOD is good...All the time! '71 swb custom10 barn find-68K original miles 72 K5 CST rust bucket, but runs and drives 84K miles |
05-19-2004, 10:48 PM | #2 |
I haven't heard of one.. I believe the 14bFF started in '73-'74
Support The Board |
05-19-2004, 11:22 PM | #3 |
Just like to part out trucks!!
Matthew, I got some 4.10's, 4.56's, and 3.73's 14 bolts up here. Do some trading on that swb 4x4 you have.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
05-20-2004, 01:00 AM | #4 |
i have a 14 bolt ff in my 72 and it went in just fine, if you find one from the 1 ton trucks 73-87 they should fit with no perch mods.
Ryan |
05-20-2004, 11:36 AM | #5 |
ryanroo-thanks for the info
teeitup-randy, let me know if you have any with 40" C to C spring perches. I'm needing this in 4.56 from a single rear wheel(SRW) truck to match the D60 going up front . Also, I'd prefer an open carrier so I can put a detroit in. Now am I picky or what!!!! If i can't find a SRW with correct perches, would it be easier to convert a dual rear to single or just move the perches? Matthew
05-20-2004, 11:45 AM | #6 |
if you find an axle from a dually truck, there's a good chance it is a dana 70. about the same as a 14 bolt, except 10 bolts on the diff cover vs 14.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
05-20-2004, 09:10 PM | #7 | |
05-21-2004, 05:10 PM | #8 |
FYI: If you end up with a '73 axle and you have a problem getting wheel cylinders, get '74 rear wheel cylinders. The '73 cylinders were only used for one year. The '74s take different lines but they are easier to find. Everything else should be the same. Also if you want to put a Detroit locker in it, make sure you get an open carrier not a posi.
'70 K-20 San Diego, CA |
05-20-2004, 04:00 PM | #9 |
Suburbans RULE!
The 14BFF that came in the 1-tons have a C to C distance of 40.5" Our old trucks have a C to C distance of 40". The 1-ton 14BBF will bolt in with a bit of prying on the springs. You will still need to move the shock mounts though.
I used a 3/4 ton 14BFF and just moved the perches and shock mounts.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
05-20-2004, 04:38 PM | #10 |
I'll try to look tonight Matthew.
05-20-2004, 07:24 PM | #11 |
73-80 2wd 3/4Ton Crew cabs also have the narrow spring perches.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
