05-23-2004, 12:28 AM | #1 |
Location: biwabik, minnesota, what is this white stuff out here
after market radio ?????
i just put a radio in my truck tonite and every time i hit the brakes or sit at idle , the radio cuts out, it loses all power but when i give it gas it comes back on and stays on the station it was on, all the lights flicker on the face of the radio. what can be causeing this to act up like this? thanks Mark
05-23-2004, 12:30 AM | #2 |
its all about the +6 inches
Sounds like you have a stock externally regulated alternator, and it might be getting weak.
Your stereo has a built in protector, if the power level drops off too low, it'll shut off to protect it's self. I would update to an internally regulated alt and maybe rewire the stereo too. The memory wire on some models is more than just memory and carry most of the power to the head unit. If you were to wire that to the post on the inner fender right by the battery, it'd get all the power it needed. |
05-23-2004, 12:34 AM | #3 |
do i run the memory wire or the power wire to the post????
05-23-2004, 12:53 AM | #4 |
Memory.
But if your alt isn't putting out enough, then it won't help. |
05-23-2004, 12:57 AM | #5 |
thanks for the help longhorn that has solved my ??? on that
05-23-2004, 09:36 AM | #6 |
The oddest Todd around
I hate them external voltage regulators. Whether that's the problem or not I would still suggest getting rid of it.
I found a simple wiring diagram on the internet to rewire the altenator for internal, and the altenator was off of a 95 or 98 silverado. High amp, internal voltage regulator, no more problems with dead or overcharged batteries. What could be better? |
05-23-2004, 10:24 AM | #7 |
do u remember what site it was that had the wiring diagram? todd,,,,, or does any one on the board have a diagram to change out the altenator?
05-23-2004, 11:25 AM | #8 | |
Thats the Hillbilly way
Part # CT27555 cost is 13.95 . This is a great mod that also is a must for ,HEI and the Headlight conversion really helps Good Luck
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
05-23-2004, 11:19 PM | #9 |
what year alt will work on my truck when i change it over to internal regulator?????
