Old 05-26-2004, 03:35 AM   #1
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
HEI relay install(PIC'S)
I installed a relay to power up my HEI today.
Pretty easy install.
I also installed a relay for my heated o2 sensor.
Here are a couple pic's.
ALL the pic's can be viewed HERE
The relays I used.rated at 40 amps.They are DPDT(Double Pole Double Throw) relays.$3.00 each at my local electronics wharehouse.
Ran these wire from a existing IGN. splice at the IGN. switch to trigger the relays on.
Here is the splice I had made at the IGN. switch(kinda hard to see)
I replace my existing 1 wire o3 sensor with a 3 wire(heated) o2 sensor.Here is the retrofit harness.
Here's the new 3 wire o2 sensor installed in the drivers exhaust manifold.
This is the power feed to the relays.Red goes to the HEI relay(12g wire).Blue goes to the o2 sensor relay(16g wire).
The circuit is protected by a 12g fusable link(light blue wire).
All hooked up now.
Here's the voltage now being sent to my HEI coil 14.12volts.
Should produce a nice arc!
Took me an afternoon to do this project (pissed around alot though) and maybe $10.00 in materials.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-26-2004, 05:42 AM   #2
Jimmy72custom
Jimmy72custom's Avatar
Clean looking wiring job. I like the color of your Blazer.
Jimmy72custom is offline   Reply With Quote
Old 05-26-2004, 11:12 AM   #3
dubie
dubie's Avatar
Just sent you a PM about the wiring Bobby
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-15-2004, 07:43 AM   #4
Huck
Huck's Avatar
Bobby, nice work. Might want consider doing you headlights/tailights. You can also upgrade to H4's peeppers from Ricks for about $40. shipped. Big difference when driving at night!!
May just have to go get some of those relays---
Huck is offline   Reply With Quote
Old 06-15-2004, 12:30 PM   #5
BobbyK
BobbyK's Avatar
Huck,I did the H-4's with relays a LONG time ago.
That was actually one of my 1st wiring mod's.
Super bright headlights eversince...it's awesome
As far as the tail lights go I got a set of the LED replacements.They draw next to nothing as far as amperage goes so the stock wiring harness to them is plenty.
These LED replacements.
Thanks though.
