Old 05-26-2004, 09:12 AM   #1
jason952
close to the end, but need some help...
hi guys,
I got the motor in, but I need a little help with the brackets and a few wires I didn't notice the first time around:
pic1: how should the power steering and ac go on there, I have the other brackets, but can't figure them out....
pic2: what is this red connector, it comes out the firewall with the tranny wires, but splits into the trans connector and this one
pic3: This a vaccuum connection to this module on the firewall, do I need to reconnect it, what's it do?
thanks,
jason
jason952 is offline   Reply With Quote
Old 05-26-2004, 10:45 PM   #2
jason952
ttt any ideas?
Old 05-26-2004, 10:53 PM   #3
ocbaud
Garage Queen Material
http://www.ocbaud.com/pictures/engine/350side.jpg
best picture i have of the power steering pump.
what year is your truck?
the wire and thing on the firewall go to the lockup controls on your tranny. i took all of mine off of my th350c.
ocbaud is offline   Reply With Quote
Old 05-26-2004, 11:00 PM   #4
jason952
hmm, didn't notice those from before. it has a 4 prong white connector on my 700r4, don't remember any others....it's an 85, was bolted to a 305.
thanks
jason
Old 05-28-2004, 06:39 AM   #5
TwinTurbo
TwinTurbo's Avatar
Taking the TCC off of the 350c isn't that big of a problem but I sugest you run a tranny cooler. On the 700R4 however it is a problem since the trans was designed with the TCC in it (350 was upgraded to have it). Without the TCC the transmission will run significantly hotter on highway speeds and will fry pretty easily if you drive at high speed at constant rpm/throttle pos. If you feel the TCC is annoying put a switch in the circuit so you can turn if off and back on for long highway cruises.
TwinTurbo is offline   Reply With Quote
Old 05-26-2004, 11:01 PM   #6
1FaastC10
1FaastC10's Avatar
the red connector has something to do with the EGR bleed solenoid if i remember correctly.
1FaastC10 is offline   Reply With Quote
Old 05-27-2004, 12:39 AM   #7
greg0380
Yeah, like 1aastc10 said, the red wire looks like the egr bleed sol. connector. The other thing mounted on the firewall is your VAC TIP IN switch. I have an 85 305 also and you probably have (used to have) electronic spark control mounted above the glove box. The switch went in to that along with some other stuff. If you ripped out the ESC then you don't need it. Check the original emission sticker under the hood and you'll see it. Good luck...
greg0380 is offline   Reply With Quote
Old 05-27-2004, 12:59 AM   #8
Jonboy
Slots go on anything!
your A/C bracket is mounted one hole too high. Move it down. There should be another bracket thet bolts over the #1 exhaust port. Then put a stud in the lowest hole in the front of the head, and hang the P/S pump from that. The slide towards the pass. side should liune up with the tapped hole in the water pump, under the two bolts that hold teh water pump on the block. Clear as mud? Should fall right into place.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-28-2004, 12:44 AM   #9
jason952
thanks all, I got it all hooked up today. The brackets fell in pretty easily after sleeping on it and looking at a few pics here and on ebay. Even got it to crank over tonight!!! big moment. It caught for a second on ether, but wouldn't do much else. At least it seems the timing is right.
ONE more ?: do I need to reconnect that vac line somewhere since I am still running the ESC setup.
I will drop that egr connector.
thanks!
jason
Old 05-28-2004, 01:16 AM   #10
greg0380
If you're gonna keep the ESC, yeah you should hook up the tip in swtich. I believe it goes to manifold vacuum. If the original emissions sticker is there, it should show it or I attached the one from my truck. You may want to think about bagging the ESC, it messes with your timing. I had trouble with mine. There is any easy way to bypass it.
Old 05-28-2004, 09:25 AM   #11
jason952
thanks, I will hook it to man. vac.
hopefully running today!
jason
Old 05-28-2004, 09:22 PM   #12
jason952
well, I got it cranking, but that is all it does...I think there is no spark. there is power to the dizzy pink wire. but seems to be nothing at the plugs.
jason...checking archives. thanks
