05-29-2004, 11:23 PM | #1 |
i love summertime
adjusting doors
im trying to adjust my passenger side door, its rubbing up in the top back corner when i close it, im thinking that i need to loosen the bolts on the top hinge but its behind the fender, i figured if i loosened them i could lift on the back part of the door and then tighten them, that should stop the rubbing, but i cant get in there and i dont wanna take my front fender off, whats the trick guys?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
05-29-2004, 11:40 PM | #2 |
AKA Phillip Johnson, AKA BANNED
Know any fat chicks? Get one to hang on the end of the door. That should do the trick. Other than that, take off the fender and do it right. You could remove the bolts from the door end of the hinge and then shim them. Ive done that. I like the fat chick idea though. he he he
05-30-2004, 12:35 AM | #3 |
PROJECT 7DEUCE
I have to agree in order to do it right you should pull the fender....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-30-2004, 09:47 AM | #4 |
I use a Snap On Wrench, no. S9619 for adjusting doors with the fenders on. A little tricky but it works.
Jim |
