05-30-2004, 12:15 PM | #1 |
BlahBlahBlah
ride height for looks and usability?
ive been working on what i want to do tire/wheel and ride height...im going to go with 18's but i dont want super thin sidewalls and i dont plan on dragging it on the ground. i do want to get close to filling up the wheel wells. what does it mean 4/6 drop? 4 in front 6 in back? best achieved with drop spindles and lower springs or air bags? i plan on using this for work which means i could have close to 500 lbs in the rear at times. im also going to use it to tow at times. air bags in rear to compensate for loads? anyone use their trucks like this? i dont even know where to start here...any thoughts would be appreciated...thanks.....oops forgot to mention this is for my just aquired burb. i have pics of it on earlier post but i dont know how to link to it from here.
05-30-2004, 01:48 PM | #2 |
I purchased my 4/6 drop kit/package from http://www.earlyclassic.com
There are a few "Stance Photos" you can look at and judge for yourself. Good Luck!
'71 Chevy C-10 - Current '62 Imapla SS - Traded for my current '73 Nova Hatch - traded for ATC-350X '73 Chevelle Deluxe - First car (R.I.P) DEERFIELD, MA |
05-30-2004, 08:02 PM | #3 | |
BlahBlahBlah
05-30-2004, 02:05 PM | #4 |
if i were u, id go with 2 1/2 inch drop spindles and 1 1/2 inch springs in the front and in the rear go with airbags. u will need an adjustable pan hard bar and shock relocators all the way around. you will also need new shocks. also, you can only use the spindles if u have disc brakes up front. and for the bags you will need a tank and compressor
70 longbed 496/th400/Ford 9" |
05-30-2004, 05:57 PM | #5 |
a 3/4 drop looks great and you won't have to worry about weather or not you'll make it over the speed bump.
05-31-2004, 03:19 PM | #6 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-31-2004 at 03:30 PM. |
05-31-2004, 08:17 AM | #7 |
Watch out for your cornhole !
I've got a 4/6 drop on my truck and I haul anything that the tailgate will close on.
Awhile back, I hauled a fully dressed (all accesories on it) 454 big block and Turbo 400 trans all over the place with no bottoming out or anything.
05-31-2004, 04:59 PM | #8 |
no offense taken. i thought of all the things you did but i didnt have the time to post all that i was kinda in a hurry and thought i would say what i would suggest he do. it sounds like his truck is going to be pretty nice (lowered with 18s) so i figured he would want to do it right since it sounds like he is able to do it right. the tank and compressor is nice but not mandatory. my grandpa did this on a truck he had a while back ( the thing with the schrader valves) i was just saying that it would be nice and handy if he got the compressor and/or tank.
