Our 70 sb, 1/2 ton with a 350 ci (mild comp cam and dart heads) We need to change out the dual pumper that came with the truck. We are thinking along the 600-650 cfm but which carb is best for the money, Edelbrock about $200, the demon 300+ the holy is from 220 to 390. I want the best but the best price is important. I have herd some good things about the edelbrock square bore. Thanks Ed ke6bnl@juno.com
------------------ Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed Sorry 50 F1 pu Sorry 63 Ford Econoline pu
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
![]() Join Date: Dec 1999
For reliability and easy to screw with(if you ever have to)i never have much id opt for the Edelbrock or Carter for your truck,if you want performance get the manual choke model-cheaper and run fatter,if not i have about 10 Holleys in a box,and lots of their parts,wont run one on a daily driver ever again!!!!maybe a toy???
OH yeah get the 600 manual choke or even the 750 with electric for the description of your motor-sounds pumped up a bit.Dont go too big carb like alot of people.on mostly stock 396-402's i run a 600,thats what they seem to like best so far,and not much reason for more.i had a 780 Holley on a mildly built 396 and i HATED that thing!!!!worst mistake i ever made-ended up buying the 600 Edelbrock,adjusted the 2 screws once about 5 years ago,havent seen it since.The Holley would have been apart,adjusted,off many times,thrown,and eventually under the bench or at a swapmeet,maybe its just a bad one some people swear by them.Just remember DONT over carb.funny when i was at circle K kid had the hood off his later 70's Camaro,i asked whats the motor it looked good he said a big block 350(i snickered quietlty)stock everything except a Torker intake,a 800 Holley,and headers,bolted to some crap-packs,said it was one of the fastest things in town,i just about said wanna race my big old pickup,but i resisted,didnt want to make him look to bad.bet its a turd off the line!!!!my mostly stock 402 in the truck,loves to baste the tires,really goes when it finally hooks up.guess i better get that posi in there someday!!!!by the way all my motor has is a 600 edelbrock,performer intake,headers,2 1/2 exh,seems to be a good little combo so far,got a 468 for it next.
67-72 Addict!
I got a Carter 625 cfm electric choke and have had no problems at all.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
