05-31-2004, 03:34 PM | #1 |
Franko72
Rare Vacuum guage
I was thinking of installing the fac. vac. guage to cover the only empty spot on the instrumentation. will I have to change the whole dash bezel because of the circuit blue print , or would I be able to just add the guage?
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
05-31-2004, 04:20 PM | #2 |
i think you will need a new plastic part that shows all the numbers, and the gauge it self, that i think should do it.
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
05-31-2004, 06:07 PM | #3 |
BlahBlahBlah
what is this rare vac. gauge?
05-31-2004, 06:23 PM | #4 |
A vacuum gauge reads manifold pressure [vacuum] expressed as "inches of mercury." For example when your foot is in the throttle, the numbers will be low (5"), but coming downhill in gear, backpressure will build up to read (17" - 20"). The needle on the dial will tell the operator his best economical burn rate when you let off the accelerator a little and the RPMs drop but the speedo stays constant and the vac increases. Also a bouncing needle will tell you if your valves are sticking. And if you got the stereo up real loud and the vac ga. needle drops to zero -- your engine stalled. LOL.
I think some vendors have NOS or re-pop OEM style gauges. They were standard on this vintage 40-50-60 trucks. I would be more apt to trust an aftermarket mfr like AutoMeter to make a good instrument. |
06-02-2004, 07:39 PM | #5 | |
BlahBlahBlah
06-02-2004, 07:49 PM | #6 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
06-02-2004, 07:58 PM | #7 | |
BlahBlahBlah
06-02-2004, 08:04 PM | #8 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 06-02-2004 at 08:07 PM. |
05-31-2004, 06:24 PM | #9 |
Not terribly rare, you will need a inner can, lense and the gauge, the PCB is the same.
These gauges came on the larger trucks for the brake system. |
05-31-2004, 08:18 PM | #10 |
Franko72
what I meant was that you dont see many factory installs with the stock equipment vacuum setup.I was curious were to get the factory items that are original and if they could work with existing non vac. setups. they are rare in that respect . arent they?
05-31-2004, 09:46 PM | #11 |
Check in big dump trucks. If you wanted to add a tach and a vac gauge there are kits available for that, not sure if you can get just the vac gauge alone as a kit aftermarket. The vacuum gauge didnt come as an option on 1/2, 3/4 or 1 tons.
05-31-2004, 10:14 PM | #12 |
Franko72
I wonder why the empty space is there next to the left of the oil pressure guage?
06-02-2004, 10:23 PM | #13 |
Franko72
I dont think that they are aftermarket conversions . I could be wrong but I have seen these listed as rare items several times.I believe that it came as a factory stock item
06-02-2004, 10:40 PM | #14 |
Like was said previously, they did come in the 40, 50, and 60 series. They never came in the 10, 20, and 30 series. The people that have them in there smaller trucks put them in. I have one in my 1/2 ton, but it taken from a larger truck and put in.
The 'spare' hole is in the 10, 20, and 30 series because GM used the same setup in all of their trucks in those years - 10-60 series, so they put the empty spot in the smaller trucks. Some of the big trucks also came with an air pressure guage in that spot. Those seem to be hard find as well. Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-02-2004, 11:16 PM | #15 |
So I guess they were "optional" in the 40-50-60 series trucks. The OEM is sort of rare -- no idea of value -- I saw a repop in a vender's catalog for $50 +.
CG your Sun gauge looks like it's seen some miles. An aftermarket gauge maybe cost $10 or $15 from JC Whitney back in the day. I have a Moon Eyes Vac I bought at the local hot rod shop many years ago on the pick-up. Still worked last time the truck was running. I have a new AutoMeter Vac for the Jimmy waiting to be installed. It maybe ran me $30. Once you get used to them, they're neat to have. |
06-06-2004, 12:55 AM | #16 |
It's not going to be "optional" as in " ... and I'll take a vacuum gauge too" when I buy it.
It's going to depend on the type of braking equipment installed in the big truck. If you have Air Brakes, you are going to get the Air Pressure gauge. If you have the Vacuum assist braking you will get the vacuum gauge. If you have the standard, base hydraulic braking, you will probably have no gauge - neither Vacuum nor Air Pressure installed; and just have the blank hole.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
06-06-2004, 11:02 AM | #17 |
love my truck
I got a gauge set I got off a tandum. I pais $80 for the whole truck.Annywais heres my guage cluster.
