06-01-2004, 07:52 PM | #1 |
Four Wheeler
Help with steering arm removal...
I just began the install of a 4" Tuff Country lift - and will be putting on a drop-down steering arm. However, the stock arm does not want to come off. I've removed the nuts, but per the instructions there's tapered 'locks' that hold the steering arm onto the knuckle. It says to tap lightly to release the locks. I've tapped lightly, moderately, and used a 2-lb sledge in an attempt to persuade this thing to move. Those nuts aren't cooperating. Being an '84 model I bet this stuff hasn't been touched since the truck was new.
I can't really continue with the lift (to my liking) without replacing this steering arm. HELP! Suggestions????
'84 K20 4x4 350 V8 - Weiand intake - Headers - 4" Tuff Country lift - 35x12.50 ProComp M/Ts on 15x10s |
06-01-2004, 08:29 PM | #2 |
well, get a 12 pack, a couple packs of smokes, some good tunes, and a bigger hammer. its gonna take a while... i beat on the ones off of my '79 K10 front axle for almost 3 hours, the arm is hardly recognizable. and all i have accomplished is one of the cone washers came out. still 2 in there, and they probably will be when i sell it or trash it. i found a deal on a Dana 60, so im ditching the 10 bolt idea.
06-01-2004, 08:35 PM | #3 |
What i do to get them off is soak them down with PB pentrating blaster its kinda like wd-40 but alot better Then put the nuts on the studs and kind hit them to jarr the cone up if that doesnt work i apply heat and hit the arm I have seen some that required alot of time others just fall right off.
\ If you have trouble getting the new one all the way down i have found an old lug nut will help to pull it down. |
06-04-2004, 10:48 AM | #4 | |
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
06-03-2004, 01:02 AM | #5 |
Four Wheeler
Good news! I ended up getting that !@#$ steering arm off. It just took a good beating. I pounded the end where the draglink connects for about 10 minutes and ta-da, those little tapered lock nuts came up enough for me to get them out of the way.
06-04-2004, 10:10 AM | #6 | |
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
06-04-2004, 10:47 AM | #7 |
I didn't have much trouble getting mine off, those tapered will actually twist out sometimes, mine did anyway, I just beat mine until one came loose and then actually twisted it out and then the next one would get loose and repeated until all 3 were out and the arm came right off, I couldn't figure out what everybody was fussin about, mine came off a 79 axle and looked like it had never been changed.
