Old 06-04-2004, 01:24 AM   #1
Radiatta_71
Radiatta_71's Avatar
Removing ignition - Help!
I forgot the process on removing the igntion key assembly. I have my key and a paper clip but which way do I turn? I have tried all directions but it won't pop out.
Any suggestions?
Radiatta_71 is offline   Reply With Quote
Old 06-04-2004, 01:36 AM   #2
typhoon
I just took mine out yesterday, I stuck in the paperclip, turned counter-clockwise, then a wiggle jiggle, and it slipped out like a fart after thanksgiving dinner.
typhoon is offline   Reply With Quote
Old 06-04-2004, 02:05 AM   #3
67shortie
Green club
67shortie's Avatar
I had to get the key in there, turn it to ACC and push a paper clip in there and pull. Seemed to work mint.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 06-04-2004, 07:09 AM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
removal process down ... how do you get the new one back in ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 06-05-2004, 10:59 PM   #5
thisolechevy
Unhappy HELP!! here too
Hey I can't seem to figure out how to get my ignitoin switch out either!! I broke my key off in the ignition and was using a screw drivier to start and operate my truck, but got tired of that so I bought a new Ignition lock cylinder from LMC and now can not figure out how to remove my old one??? I put a papper clip in the hole, turned the key counterclockwise, and felt it click but then what I can't pull it out its stuck in there. And also does just the lock cylinder come out? or the cylinder and the bezel?? any helps is appreciated
thisolechevy is offline   Reply With Quote
Old 06-04-2004, 10:39 AM   #6
71Rat
ran out of money
71Rat's Avatar
you should just be able to push it in and turn it clockwise and it should be in..... might not have to even turn it....
i think thats how i put mine back in
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 06-05-2004, 10:36 AM   #7
Blue Beard
Blue Beard's Avatar
Be sure the Battery is disconnected before you do it.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 06-05-2004, 11:14 PM   #8
typhoon
just the lock cylinder will come out. The bezel will thread off after the lock barrel is out. did the key break off flush in the lock barrel?
Old 06-06-2004, 08:48 AM   #9
thisolechevy
No it did not brake off flush, there was enough room to put a screwdriver in and turn the ignition cylinder
Old 06-06-2004, 01:16 PM   #10
typhoon
try cutting a notch in a cheap or old common screwdriver so you can turn and pull on the barrel.
Old 06-06-2004, 11:15 PM   #11
thisolechevy
Alright but I have a question If I were to remove the electrical plug from the back of the ignition switch would I be able to hot the engine from the plug? I know that the RED wire is the hot wire, but which wire is starter? and is this possible at all?
Old 06-06-2004, 11:27 PM   #12
typhoon
sure, you can jump it that way, or add a switch. The starter motor will run off of the purple wire, applying power to that will energise the starter solinoid. it will work fine, it just won't be very proper, but if you not concerned with being proper don't worry.
Old 06-07-2004, 01:21 PM   #13
thisolechevy
HA HA I am back in buisiness yeah!!!! Thanks Typhoon I got the old lock cylinder out, and the new one in it works great. With the old one in it always sounded like my bettery was about to die when I went to crank it, but the new one made a big improvement it just cranks right up!! thansk again for all the help all of you.
Brad
Old 06-07-2004, 02:34 PM   #14
thisolechevy
OHHHH ARGH I just took my truck the hardware stoer for a test run and guess what? again it wouldnt start for me!!! uh I hate it. Like I said before I replaced the ignition cylinder and I thought it was fixed, I have some questions. My engine is running alittle warm lately (I am in the process of fixing it now) but it runs about 200deg. would this affect the way my starter works? like if I were to have a faulty starter would it work cold just fine, and then when the engine heats up not work? I have a brand spankin' new battery and alternator
The thing that gets me is you can push start the truck just fine, so it has power to the engine, it just wont start, the starter wont even click. Is there some type of relay? or wiring I need to check?
Brad
Old 06-07-2004, 02:44 PM   #15
Russell
Professional Grade
Russell's Avatar
A hot engine will fry your starter... Mine got a little warm on the manifolds when I ran it too lean once, my starter hasn't worked the same since... Its like my battery is dead when the truck is warm, but it has enough to get the truck to start (usually starts on the first to second crank) when the truck is cold, on the other hand, it will fire right up like normal.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-07-2004, 04:00 PM   #16
thisolechevy
Hey I just found out that the truck will start up fine once i let the engine cool to under 160 deg. so it must be the starter. right???
Old 06-07-2004, 07:29 PM   #17
typhoon
The starter and solenoid both are affected by heat, usually trucks with headers have the exact problem you are discribing beacuse of the heat generated in that area. the cheapest thing you could do is install a heat shield so that there is a seperate air passage around the starter and solenoid, this will keep it cool and working when you want it too.
Old 06-07-2004, 09:02 PM   #18
Blue Beard
Blue Beard's Avatar
Have to agree with typhoon....
Headers too close to the starter have been an issue....they do make heat shields for the application...
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 06-17-2004, 01:18 PM   #19
71-longbed
71-longbed's Avatar
im trying to replace my ignition switch .. got the ock cylinder out .... the manual says after that .. to "remove metal ignition switch nut " ... i dont see any nut !!! please help ... i need to drive this truck today
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 06-17-2004, 01:40 PM   #20
CPNE
Resident Curmudgeon
CPNE's Avatar
The "nut" is the bezel itself. You may need to gently tap the bezel counterclockwise with a hammer and flat screwdriver. Lodge the screwdriver in one of the detents in the bezel to get it to move.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-17-2004, 02:30 PM   #21
71-longbed
71-longbed's Avatar
I got it ...... now i know how those things fit in there :p
everything works!!!! truck fired right up .... hope it clears up my catchin' starter issues
thanks for the responses
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
