Old 06-06-2004, 12:32 AM   #1
mustanglx347
need help with gas guage, not what you may think...
I bought an '82 Blazer which had been converted from a diesel to a small block. The wiring is pretty butchered. My gas gauge sits on full with the key off, then when the key is turned on, the gauge goes past full into the 3 0'clock position. Well, I did some wire tracing, and found the wires from the sending unit have been cut near the firewall. There is a yellow and orange I think. The black is grounded. I am assuming one wire sends power to the sending unit and the other sends the signal to the gauge (I could be worng). Does anyone know which is which? Also, I need to know which wire on the back of the gauge cluster goes to the fuel gauge.
Oh, BTW, the same thing happens with my oil sending unit. The sending unit has the wire plugged into it on the top, but the gauge pegs out when the key is turned on.
Someone please help...It will be greatly appreciated.
Ben
'71 Chevy stepside
'50 Chevy 5 window
'82 K5 Blazer
'90 Mustang-stroked and sprayed
'95 Nissan 300 ZX
'04 Jeep Grand Cherokee
mustanglx347 is offline   Reply With Quote
Old 06-07-2004, 09:47 PM   #2
chevythunder
chevythunder's Avatar
i know that there is three wires. one from the sending unit, ground, and a hot wire. i know i mixed up the hot wire, and the sending unit wire and had the gauge reading at the 3o'clock position. check the hook ups. could be backwards. just some info
oh and one more helpfull hint. i know that the sending unit wire has a diffrent voltage than the powerwire. if u had atleast 3/4 tank, it would help out even more. power wire has more voltage than the sending wire. (of coarse mine could be diff.) (if u got a voltmeter)
chevythunder is offline   Reply With Quote
Old 06-08-2004, 10:00 AM   #3
mustanglx347
Thanks for the reply. I have a volt meter, but, the wires from the tank are cut back on the frame under the cab. My problem is, I can't find which wires they correspond to on the inside of the firewall. The ground is still hooked up at the tank. Does anyone have a schematic or know where I could get one so I could trace these out??? i am aobut to rip the whole Blazer apart just to fix the gas gauge.
'71 Chevy stepside
'50 Chevy 5 window
'82 K5 Blazer
'95 Nissan 300 ZX
Old 06-08-2004, 12:45 PM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Not sure if it would work but the one I have is for a 73-80? model schematic. If you think it would let me know your email and I'll send it to you.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
