Problem with Rad. supports....HELP
I removed my radiator and installed new mounts (rubber) and new upper rad. supports. The mounts are the right width but the radiator now sits up about a half in. higher than it was and I can't fasten the upper supports down without the other end sticking up. Is there a trick or are the new mounts just too thick?????
blood type; Retumbo
are they direct replacements? if so they will have a nipple that fits into a hole in bracket. if these are not installed correctly it would raise the rad about 1/2 in.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Thanks for your help...........I guess I was in a hurry. I went back out took it all back out and reinstalled with no problem.............thanks again!!!
