Old 06-07-2004, 08:54 PM   #1
85Silveradoin04
No radio, heater, or power windows
Thank you google! I've been looking for a site like this for a while. Help is needed!
I replaced the steering column because the tilting was loose (pain to drive) which was donated from a junker 85 or 86. Not sure.
After plugging everything up, It startup and all lights, horn, blinkers, wipers and everything works. Except for the radio, heater, and power windows. I cant figure thus out, Everything looks right. I check fuses............they we fine. Any ideas?
Oh yeah. Cool site.
85Silveradoin04 is offline   Reply With Quote
Old 06-07-2004, 10:39 PM   #2
Russell
Professional Grade
Russell's Avatar
That'd be the switch at the base of your steering column
Put the one from the old column onto the new one, and it should be good to go again
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-08-2004, 01:58 PM   #3
85Silveradoin04
Russell,
Could you be more specific as to what this switch is. I mean, I pulled the iginition switch, blinker switch, and wiper delay. There is also a thin back connector that goes from the column to the wiring harness as well. This is plugged in too. I'm beginning to think that this column came out of a truck without power windows. Could this be the case? Do you have a pick of what this switch should look like. That would be AWSOME. Thanks for the reply.
Old 06-08-2004, 08:11 PM   #4
85Silveradoin04
Are there differences in the ignition switch from power to manual windows? Everything buttoned up fine which is why this is weird, also all documentation I read referes to the switch being compatibile between years with the exception of the tilt, which both columns have.
Old 06-08-2004, 09:23 PM   #5
85Silveradoin04
Ok Ok Ok. Found it. Thanks to Russel for the tip. It was the ignition switch. Only becasue when I inserted the connector, one of the pins on the switch bent down . After adjusting it and reinstalling, it all work fine.
IF I EVER HAVE TO MESS WITH ONE OF THESE AGAIN IT WILL BE TOO SOON.
Old 06-08-2004, 09:26 PM   #6
Russell
Professional Grade
Russell's Avatar
lol, sorry about that, I didn't really think to tell ya about what I meant, and I couldn't find my digital camera to get you a picture of it...
Glad ya got it going though!
Old 06-08-2004, 09:34 PM   #7
85Silveradoin04
No problem. Glad its done too. It really sucked when I got to work only to find out the Windows would budge and with the forcast showing heavy showers late morning........
Old 06-08-2004, 09:32 PM   #8
Russell
Professional Grade
Russell's Avatar
Hey, by the way, welcome to the forum!
You stumbled across by far one of the best forums out there, over 10 000 members, with thousands of posts every night
This truely is the best place to get help for your truck! The guys here can save you thousands of dollars by showing you how to do stuff yourself, and can be best buds with ya, or be a shoulder to cry on. We really are like a big family here
Old 06-08-2004, 09:36 PM   #9
85Silveradoin04
Looks great and glad to be a part of it. Thanks to you!
Old 06-08-2004, 09:49 PM   #10
Russell
Professional Grade
Russell's Avatar
Any time! Plus, I just found my camera, so now I can take pics of stuff again, I was missing that thing...
