Old 06-08-2004, 10:12 PM   #1
70GMuttC
70GMuttC's Avatar
Help me find my Rearend
I just started tearing my 1971 K10 project apart. I opened the rear diff to start cleaning it up and found it wasn't opened, but had a posi or locker of some kind. We started looking closer and found the axle perches are 2" wide (from a car?) instead of 2 1/2" and have some really bad welds on them as well as the shock mounts. But what I really need help with is the gears in the rear, a 12 bolt, but the gears are stamped with a 3/83 manufacture date. So if anyone can help...PLEASE?!?!? Oh yeah the whole gear stamp if anyone can decode it: 1 GM 339635 11 41 3 83. I'll post pictures of the posi lookin thing when I get to work tomarrow.
Thanks,
Jason
70GMuttC is offline   Reply With Quote
Old 06-09-2004, 04:59 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Looks like 3.73 gears. Post up those pics of the differential when you get them.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-09-2004, 11:55 AM   #3
70GMuttC
70GMuttC's Avatar
Here are some pics
http://community.webshots.com/album/151012467eTZxHW
Old 06-09-2004, 12:41 PM   #4
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
Unless you have a really really bendy neck, just use two mirrors....
:p
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Old 06-09-2004, 01:05 PM   #5
LONGHAIR
I would say that the numbers (GM 339635 11 41 3 83) 11-41 are the gear ratio .......3.73 and the date 3/83 and your pics show what GM calls "Gov-Lock".
They are known to be weak with larger tires/higher horsepower.
The little springloaded "governor" allows some wheel spin/slippage before trying to stop it. The governor is supposed to only allow one wheel to rotate a certain percentage faster than the other.........but it only works below approximately 20 MPH. The mechanism works by centrifugal force and once spinning fast enough it doesn't try to lock. The idea was to be smoother than the old fashioned Posi unit..............smooth doesn't translate to heavy duty though.
LONGHAIR is offline   Reply With Quote
Old 06-09-2004, 01:07 PM   #6
70GMuttC
70GMuttC's Avatar
How weak are they known to be? I am going to run 33's and around 350 hp.
Old 06-09-2004, 12:45 PM   #7
Lippyp
English Chevy Owner
Lippyp's Avatar
I just prefer to use my hands, can even find it in the dark that way!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
