06-11-2004, 12:05 AM | #1 |
Before and After
Exhaust routing on lowered trucks
Where do you get the muffler guy to route the exhaust tubing on a 4/5" dropped LWB?
What header is the best? I am thinking a Shorty to keep it tucked up. I would like to have it protected. What are your thoughts on where it exits, I would like it to exit Rear corners, but I think I will get it to exit before the wheels. Because of the bends it will have to take from the axle being so close to the bed. Comments.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
06-11-2004, 08:16 AM | #2 |
here's mine, and my truck is lower then 4/5it's dumped before the rear end and the 2 1/2 inch pipe hasnit rubbed the ground yet.
http://ctw.truckmoxie.com/gallery/2low72/80411.jpg http://ctw.truckmoxie.com/gallery/2low72/80699.jpg
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
06-11-2004, 01:08 PM | #3 |
I'm doing a 4/6 drop and I'm using shorty headers and the new trailing arm crossmember that ECE has. I'm running it up in the frame all the way out the back. Then some small chrome turn down tips just outside each frame rail under the rear bumper.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
06-11-2004, 01:15 PM | #4 |
Cowboy Fan for Life!!!!!!
Does anybody have any photo's of someone running their exhaust over[I] the transmission crossmember?
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
06-11-2004, 07:44 PM | #5 |
I'm going to need to do my exhaust soon too... Has anyone routed their exhaust on the outside of the framerails (mufflers under the cab) and dump in front of the rear tires? This looks like the best way for me to keep everything tucked up tight which I need now that I have airbags. I don't want turn-downs since that's what I have now and it's deafening inside the cab when I'm stopped.
Mike Lackey '68 C10 |
