06-12-2004, 07:49 PM | #1 |
Ignition Switch wires - which one is which?
Which wire is hot when the key is on, on the back of the ignition switch?
I am pretty sure that the purple one runs the starter, so it only has power when you are trying to crank the starter over - is that correct? Which one has power when the key is any position except off? Is it the brown wire? Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-12-2004, 09:44 PM | #2 |
On mine the purple wire runs the guages and acc. it is hut in the run position.
06-12-2004, 10:24 PM | #3 |
purple wire goes to the neutral safty switxch then to the starter sokenoid and is hot when the key goes to start
06-12-2004, 10:26 PM | #4 |
the brown is supposed to be hot in all positions except off that's correct
