Prestige Worldwide
![]() Join Date: Feb 2001
Big Block parts for sale
I have a whole set of brackets and pullies for our trucks to use the short water pump. This also includes all A/C brackets, and even a power steering pump. I also have a set of 68-71 bog block frame stands that are bramd new from GM and a set of engine mounts (rubbers) as well.
$500.00 Jason jrs3498@aol.com 770-389-7785 |
Prestige Worldwide
how about them bog block parts huh.....
I meant to say big block but I am sure you guys caught that. Jason |
![]() Join Date: Apr 2000
Do you have a heat stove and the tube that goes to the air cleaner. If you do I will take them.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
What do you want for just the 68-71 bog block frame stands?
"Trucks with Class"
![]() Join Date: Jul 2000
Just want to clarify, are the rubber mounts also NEW GM?...or just the frame stands?
Prestige Worldwide
The frame stands and the rubber mounts are both new from GM. I got lucky and ran some down through a dealership. I ended up paying about $275 or so for the mounts and stands. I would consider an offer if you guys want to make one.
Jason jrs3498@aol.com |
