06-17-2004, 04:07 PM | #1 |
Garage Queen Material
removing door panels??
trying to install my alarm, but i cant figure out how to get the door panels off. all of the screws are taken out but now what?
06-17-2004, 04:16 PM | #2 |
okay, i was missing 2 screws in the arm rest.
now how do i get the window crank off? |
06-17-2004, 04:16 PM | #3 |
Silverado Stew
THere's a "U" shaped metal clip that you have to remove with a screwdriver. Make sure to keep an eye on it, it can fly pretty far.
- 1997 3/4 Ton Ext. Cab LB 4x4 6.5L Diesel - 1979 3/4 Ton Longbed 4x4 "Farm Truck" - 1984 1/2 Ton w/ '99 Vortec 350/700R4 2x4 FOR SALE Last edited by jared stewart; 06-17-2004 at 04:17 PM. Reason: He answered his own question |
06-17-2004, 04:18 PM | #4 |
www.73-87chevytrucks.com
There is a u shaped clip holding the widow crank on, Usually you ( I ) can get it off with 2 small screwdrivers on either side, since I am too cheap to buy the tool.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-17-2004, 04:20 PM | #5 |
Four Wheeler
Instead of screwdrivers, I actually bought the window crank removal tool (or whatever it is called) for a few bucks at Autozone. I've used it so many times now on different vehicles.... well worth the money.
'84 K20 4x4 350 V8 - Weiand intake - Headers - 4" Tuff Country lift - 35x12.50 ProComp M/Ts on 15x10s |
06-17-2004, 05:11 PM | #6 |
don't forget about the line of clips at the top of the panel, i find it easyest to roll the window all the way down to get thoes
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
06-17-2004, 05:27 PM | #7 |
I vote for buying the window crank tool. Its not expensive.
06-17-2004, 05:33 PM | #8 | |
06-17-2004, 07:14 PM | #9 |
It followed me home?
Why do you need the doorpanels off to install the alarm?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
06-17-2004, 07:14 PM | #10 |
Oh yeah your putting actuators in. Nevermind. How is the install going?
06-17-2004, 09:52 PM | #11 |
well, the actuators are in and everything to do with the doors is done.
a lot of the wiring is ran, but not really. my friend is coming back over saturday to finish it. he has to get the install book for the alarm from his work(car audio shop) i'm trying to figure out where to locate the brain and the relays for the remote start at. |
06-17-2004, 10:17 PM | #12 |
Are you using some sort of solenoid to kick the throttle to allow the engine to start when cold? Or are you planning fuel injection in the future?
06-17-2004, 10:24 PM | #13 | |
during the summer months like now, it isnt a problem to start it with out hitthing the gas |
