Old 06-20-2004, 02:56 PM   #1
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Starter Heat Shield
With the hot weather and all my driving around lately, my starter has been crapping out. I'm pretty sure its just overheating, since when I go to start it, there is just nothing, no clicks no armature action...nothing. still lots of power in the battery, usually just have to wait a few minutes and it fires up.
So, my question is, how do you install the shields? where do they bolt on?
I just have corvette style ramhorns, but aparently they still get pretty hot. Any help/suggestions would be nice
Thanks,
-Benson
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 06-20-2004, 04:25 PM   #2
smitty62
smitty62's Avatar
If you haven't already, I'd look at the grounds before I blamed the starter. I've driven SBC's since 1956 and I've never had a starter fail because of heat soak. Not saying it doesn't happen, just that it's a lot rarer than most think. The real problem is usually covered over when the starter's replaced, ie: accompanied by new cables, battery, alternator, etc.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 06-20-2004, 06:48 PM   #3
c10chevy69
c10chevy69's Avatar
I would check the ground cable first. I had this problem last weekend. Battery showed 12.6 but no voltage to anything at all. At first I thought it was the voltage regulator, but I cut the chewed up cable end and reattached it. No problems since fires up everytime.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 06-20-2004, 08:02 PM   #4
MandarinSixSeven
Seasonal Poster
which ground are we talkin here?
the one on the battery?
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-20-2004, 08:08 PM   #5
c10chevy69
c10chevy69's Avatar
Sorry. Yes the negative battery cable. If it's not getting good contact then you've got nothing.
Old 06-20-2004, 08:26 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You should at least here the solenoid clicking, like the others said check your wiring, may have a bad solenoid but the prices these days its easier to change the whole thing.
sneakysnake is offline   Reply With Quote
Old 06-20-2004, 09:38 PM   #7
smitty62
smitty62's Avatar
Check the grounds on BOTH ends! One is no more important than the other.!!!!
Smitty
Old 06-20-2004, 08:24 PM   #8
MandarinSixSeven
Seasonal Poster
ok cool, I just replaced the battery terminal on the negative side, see how that works
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-20-2004, 09:59 PM   #9
MandarinSixSeven
Seasonal Poster
Ya, I plan to for sure.
I just don't feel like crawling under there tonight 1/2 is better than nothing for now
And, Sneaky Snake, I've had solenoid go bad before...this one isn't like that, my old one you could hear it click, this one is just no response from the starter
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-20-2004, 10:02 PM   #10
Cruiser71
AKA Phillip Johnson, AKA BANNED
If the cable dosnt do the trick, try Ecklers or Mid America Corvette for a started heat shield.
Cruiser71 is offline   Reply With Quote
Old 06-20-2004, 10:06 PM   #11
thisolechevy
I bought mine from napa, it was only $32.00 and it did the trick! it was really easy to install also. Your starter will have 2 bolts on the butt side facing the front of the truck, you simply undo one of them and bolt on the heat shield with that bolt, and one on the selinoid (sp.???)
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 06-20-2004, 10:31 PM   #12
MandarinSixSeven
Seasonal Poster
Awesome man, thanks! Thats what I wanted to hear for if the grounds don't fix it.
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-21-2004, 12:02 AM   #13
gabet40
i bought mine at kragen, a spectre one. however i kept having that problem so it sounds like i shouldve been checkin my negative cable (or my headers were just that hot). the reason i never thought of it is cuz the started only did that when the engine was hot and never in the winter. coincidence? who knows
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 06-21-2004, 12:32 AM   #14
walker
walker's Avatar
I live in the desert where it gets hot, nothin' personal but I don't think you BCers know what hot is, and I have never had trouble with starter heat soak. Most times it is poor connections, poor cables, poor quality replacement parts, etc that is the problem.
Now when it gets cold here, and I mean REALLY COLD!!! like forty degrees, maybe you all could help me with a block heater, and snow tires.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 06-21-2004, 01:55 AM   #15
Cruiser71
cold=40 degrees?????
Old 06-21-2004, 01:19 AM   #16
MandarinSixSeven
Seasonal Poster
so, what is starter heat soak?
liike you turn the key and not a sound or what?
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-21-2004, 12:55 PM   #17
lewi
lewi's Avatar
Right, wrong, or indifferent I put one on mine and haven't had any troubles since. I think I know what hot is, over 100 degrees most summers every day for 6 weeks, 110 and above is not uncommon. I agree 40 degrees is quite cold!
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 06-21-2004, 02:55 PM   #18
busterwivell
40 is inhumane! I like it when it's about 100. I've got a 402 BB in my truck. I was going through a starter every 6 months (hot or cold) for 4 years. I switched to a mini starter 3 years ago (this August) and I haven't had a problem since.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 06-21-2004, 10:05 PM   #19
jorgensensc
jorgensensc's Avatar
I put a ford remote starter solenoid on mine and it worked perfect. i will try and find you a part number and websight. It gets rid of the problem of heat soak all together.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-21-2004, 10:46 PM   #20
MandarinSixSeven
Seasonal Poster
It was 100 degrees (american) today...but I didn't get to test it But as far as the weather goes I will probably get plenty of time to test it
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-21-2004, 10:59 PM   #21
Quagmire
A splendid one to behold
Quagmire's Avatar
food for thought, i had a similar problem and it turned out to be my ignition switch. it was intermittent though, so the problem wasn't too easy to find. i actually stumbled upon it on accident
just in case you seeking alternate troubleshooting methods
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 06-22-2004, 02:00 AM   #22
Cruiser71
Try replacing the purple wire from the switch to the starter. It happened to me. Kragan (Shucks) starters need to be installed with velcro. They only last a few weeks. I would go with a good Napa or A/C Delco rebuilt. Worth the extra money. The others seem to be a spray can rebuild!
Old 06-22-2004, 09:34 AM   #23
67chevemall
67chevemall's Avatar
Nice mini high torquer will fix that problem!
They are bullet proof!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 06-22-2004, 03:02 PM   #24
raggedjim
raggedjim's Avatar
When I had this problem the bushings in the starter were bad. When it was cool it would start but when everything got hot the bushings expanded enough for the armature to touch the stator and it would lock up. I didn't figure this out until I had put on the ford solenoid (which ain't a bad idea, it makes it so the only time the positive cable to the starter is hot is when the ignition is at start.)
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 06-22-2004, 08:14 PM   #25
walker
walker's Avatar
Cruiser71 the 40* temp was a joke. I see every one else seems to have taken it as intended. If the heat shield fixes your problem then go for it, I was just saying to check everything else first. Electrical gremlins are no fun, and are seldom what they seem to be at first, just look at the myriad answers you got to your post.
Good Luck, Andy.
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
