Old 06-30-2004, 10:07 AM   #1
WB72
Before and After
WB72's Avatar
Engine repair in the truck.
I don't have access to an engine hoist, but want to replace the oip pan gasket and seals, can this be done in the truck?
What about replacing the cam, has anyone done this? does the grill have to be removed for this?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-30-2004, 10:41 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
The pan gasket can be replaced with the engine in the truck. Not sure on which engine you have, but in most cases you jack the front of the engine and disconnect the motor mounts. You might also have to pull the distributor to keep it from hitting the firewall. Instructions are in the factory service manual, available through many of the on-line vendors. Well worth the investment.
To r&r the cam, you need to remove the grill and the radiator. Again, instructions in the service manual.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-30-2004, 10:56 AM   #3
buckola
1 Wrench / 10 Knuckles
buckola's Avatar
You'll have to lift the engine about 3+ " and support it with 2x4"s or whatever to clear the flywheel. I removed my dizzy cap and had no problems with clearance. You also have to remove ( loosen)the fan shroud. Changing the seals? not sure of the difficulty but any "flat-back " work is a pain.
For the cam you have to remove the rad and of course all the other "in the way "paraphanelia. Theres enuff room for the swap at least in a GMC.
After just completing a cam, heads, manifold swap (still doing the headers) I would have to say... PULL THE ENGINE...it would be a helluva lot easier
1970 GMC Custom
Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers
2006 Dodge Charger SRT8. 1/4 mile 13.3
1973 Z1 900 Kawasaki ( all original)
buckola is offline   Reply With Quote
Old 06-30-2004, 10:59 AM   #4
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
I replaced the cam in mine without removing the grill... but I'll also vote for pulling the motor. That's what I'll do next time.
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 06-30-2004, 11:10 AM   #5
n737nc
I just finished a heads, cam, intake swap last weekend. If I did it again, I would pull the motor.
Nick
n737nc is offline   Reply With Quote
Old 06-30-2004, 01:15 PM   #6
mrein3
mrein3's Avatar
I did a heads, cam, and put the old intake back on. I'd do that in the truck if that is all I had to do.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-30-2004, 02:00 PM   #7
COBALT
COBALT's Avatar
I replaced my oil pan gasket a little over a year ago. I had to disconnect the motor mounts, loosen the transmission mount (and disconnect the linkage so it wouldn't get bent), loosened the exhaust brackets, took off the air cleaner and pulled the distributor, and then used a block to lift the motor by the balancer until I got enough clearance to get the pan around the counterweights on the crank.
Pain in the butt. Next time I'll pull the motor. Go rent an engine hoist.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-30-2004, 04:28 PM   #8
LONGHAIR
The only time I ever did a cam in the vehicle was way back on my first car. The hot rodder in me was just beginning to grow. I can tell you that it can be done in a 69 Camaro w/o taking out the grille. I changed the cam, intake and had a valve job done too. I wouldn't go that route again........It is far easier to pull it out.
LONGHAIR is offline   Reply With Quote
Old 07-01-2004, 11:08 AM   #9
WB72
Before and After
WB72's Avatar
Sounds like I'll be pulling it. (the engine I mean)
66,000 miles.
Alberta, CANADA
Old 07-01-2004, 11:16 AM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
To each his own!
What engine is in the truck?
Fred
Old 07-01-2004, 06:04 PM   #11
WB72
Before and After
WB72's Avatar
It is a 350 with a TH350.
66,000 miles.
Alberta, CANADA
