I Found a parts donor Burb, a few ???
I want to get started of a frame for my '68 panel. I found a '68 Burb that I can get fairly cheap, but it's a 3/4 ton and my panel is 1/2. Are the two frames the same? I'd like to stay with 1/2 for the ride, plus, call me crazy but I like the 6 lug look. This Burb has a v-8/automatic, so I can use the mounts and x-member and the front clip and bumpers are in pretty good shape.
Pretty much the difference between 3/4 and 1/2 ton 2wd are the rubber body bushing and rad cradle bushing are bigger on the 3/4 ton suspension vehicles. The rear cab mount on the frame is at a lower height on the frame of the 3/4 ton but its lift is achived by the longer cab bushings.. so the 3/4 sits as little higher. Hmm but this is a sub right... hmm dont have a 2wd sub but thats the way it is with trucks... should be the same for subs possibly.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Only difference on 'burb frames is the suspension - the frame itself is the same.
you never have too many suburbans.... |
