Old 07-08-2004, 07:27 PM   #1
jorgensensc
jorgensensc's Avatar
5 speed tranny for sale 350.00!! Lowered the price!! I can Ship!!!!!
Hey all. I have a 5 speed tranny out of a 1995 camaro for sale. I just bought the engine and tranny combo together, but this tranny won't work for me. The tranny has 53000 miles on it and it is attached to a 3.4 engine. I just payed 895.00 for it from a local engine/tranny distributer. I need to get 350.00 for it. It doesn't have the shifter or the slave cylinder, but I am trying to get those as we speak, everything else is there. These tranny's are getting harder to find in good cndition. I would prefer local pickup in Houston, but may be able to deliver reasonably close for a small gas fee. I can ship at a discounted rate. I'm not sure what the rates are yet, but I will be shipping from a local company using there rates. Thanks!!
Shawn
I have also taken the engine apart to check it out and it appears in very good condition. As you can see the tranny is very clean.
I need this to be a quick sale so that I can get the tranny I need for the swap, so unfortunately no delayed payments or payment plans this time guys, sorry.
Shawn
I am lowering the price to 350.00. I need to sell it as quick as possible.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-08-2004, 11:27 PM   #2
jorgensensc
Ttt
Old 07-09-2004, 01:03 AM   #3
dinnut
dinnut's Avatar
would it work in a 67-72? and does nebody know if it would bolt up to a th350?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 07-09-2004, 01:29 AM   #4
1972C10
1972C10's Avatar
It will work in a 67-72 but it will require buckets the shifter will be under a bench . however it will need a different bellhousing that will only for on 4cyls and smaller 6
And you said will it bolt up to a th350 a th350 is a transmission So i assumed you mean SB350
1972C10 is offline   Reply With Quote
Old 07-09-2004, 01:27 AM   #5
jorgensensc
The tranny will bolt up to a 350 if you get a different bellhousing. These can be gotten anywhere since the same tranny was put behind other 90 degree engines. The bellhousing on it now is for a 60 degree engine. The bellhousing is only a few bolts and an easy swap. All junkyards have them as I'm sure a few board members have some lying around. They hold up well to the v-8s, Ford mustangs as well as full size chevies utilized this same tranny, just different bellhousings, and a few other minor differences.
Old 07-09-2004, 01:33 AM   #6
jorgensensc
I forgot about the bench seat, so it would probably need buckets, or a cutout notched toyota type seat. I thought I saw someone on the baord did something like that.
Old 07-09-2004, 03:50 PM   #7
jorgensensc
I can Ship now too!!!!
