07-10-2004, 10:07 PM | #1 |
1985 GMC Jimmy V8 oxygen sensor
Hi,
Just stumbled here. I need to replace my oxygen sensor and am having trouble locating where the old one is. I see something like it underneath the spark plugs but not sure if this is the temperature sensor. Anyone know? TIA |
07-10-2004, 11:51 PM | #2 |
Overworked and Underlaid
what kind of motor do you have?on the 80's 305 motors that had ESC they had a large object in the center of the side of the block-i dont recall what side but that is the knock sensor for the motor.you may also be looking at the sending unit for the temp gauge i believe they couple be threaded into either head but i could be wrong there-thats hard to say w/o being there or seeing a pic-do you have a pic of what you saw-that could help.to answer you question regarding the oxygen sensor its in the exhaust pipe most likely before the catalytic convertor.i may be wrong there too-hopefully someone with an o2 sensor equipped truck will chime in as mine doesnt have one.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
07-11-2004, 11:39 AM | #3 |
Thank you. It's a 5 liter (302) 4WD. The book I have covers the V6, mine's a V8.
07-11-2004, 12:02 PM | #4 |
ROCKET POWER!
It'd be a 305 cid engine, really. Ford has the 302 that's referred as being a 5 litre engine most often. Chevy made a 302 i believe for the 67-69 Camaros which is extremely rare and desirable. A 305 from a C-10 most likely would not have an oxygen sensor if the engine is original to the truck along with it's ignition/fuel/emissions systems, since it should be a carbureted (4-barrel Quadrajet) low emissions engine with an Electronic Spark Control computer (knock timing retard system).
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
07-11-2004, 01:23 PM | #5 |
rockHQ ur right on the chevy 302, came on the cameros, was a factory drag car, had a solid lifter cam in it from the factory. anways, i don't belive that anything that has a carburator would have an oxygen sensor unless someone put one in to tune the carb with.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
07-12-2004, 10:27 AM | #6 |
Only California-emissions trucks had oxygen sensors for the computer-controlled carbs. If this is what you've got, it should be in the exhaust pipe between the exhaust manifold and the catalytic converter.
Good luck!
Semper Paratus |
07-12-2004, 12:11 PM | #7 | |
Yep only cali and that's on the CCC (Computer controled Carbs). Trucks didn't get FI till 87. Honestly if your having problems and not in Cali or a real hard core emmeions area where they pull the car apart and look for CARB numbers I would ditch the CCC and get a Electric choke Quad and a regular HEI. Also your truck probably has ESC ignition. Again if it gives you problems...scrap and go to HEI.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
