07-11-2004, 08:31 PM | #1 |
help me ID this
OK just got my truck home yesterday and started going through it making sure it is safe to drive. As I was checking everthing I also wrote down all the ID numbers on the engine block I have 44 GM 3970010 what type and year is this engine, and anyway to tell what vehicle it came out of? I looked on both front and back of the heads I could not find the #. Anyone know where to look? Same for the trans but I do know it is a TH350 by the shape of the pan and location of the module. I pulled the rear diff cover off and on the ring gear I have 3817778 11:41 GM 12-71. It is a 12 bolt and with the ratio stamped on it, it is a 3:73 rear, but not sure if it is posi? I did not see any springs in the carrier unit just Ring, pinion, and spider gears. But with one wheel off the ground I would not turn. With both wheels off the ground the opposite would spin in the counter direction?
07-11-2004, 08:46 PM | #2 |
Designated A-hole!
If your rear end looks like this it's a plain old open differential.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-11-2004, 08:59 PM | #3 |
Designated A-hole!
From Mortec.com (a good site for running numbers).
3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4 BTW you have to pull the valve covers to get the head numbers. You can look them up on Mortec also.
07-11-2004, 09:06 PM | #4 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-11-2004, 09:22 PM | #5 |
Yep that pic looks like mine no posi. Oh well. I did get a 12 bolt with decent gear ratio. Thanks for the info.
