SKINNY TIRES RULE!
I just discovered my brake lights aren't working. I'm going to have to work on it tonight when I get home from work but I'd like to (hopefully) narrow down my troubleshooting before I get started.
The tail lights and turn signals work - just the brake lights aren't. What is the most likely cause? I did pressure wash the underside of the truck yesterday. As far as i know, the brake lights were working before that. ![]()
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#2 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
English Chevy Owner
Broken wire? If it's the original wire it can get pretty brittle. Mine is a horrid rats nest of spliced in bits of wire and all the insulation is rock hard. It's a job for the winter making a new loom as my lights are adapted for UK regs. Check the wiring.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
If the taillights and turn signals are working, then the wiring from the turn signal switch back is good. Your brake switch routes power to the turn signal switch which routes the power to the bulbs in the rear lights. Your problem has to be between the power and the brake light switch or between the brake light switch and the turn signal switch, (including the brake light switch).
Good luck! Jim |
December 21, 2012
I had a problem with the plug that connects to the switch on mine.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
SKINNY TIRES RULE!
I was thinking it might be the brake light switch. I'll start there. If I put the the multi-meter where the brake light fuse is at, will that give me any indication of where my problem is?
You should be able to read power on one wire to the switch. Power should be there whether the ignition switch is on or not. With the brake pedal depressed, both wires to the brake light switch should read 12 volts.
If you don't get power past the switch, it is bad or needs adjusting. Jim |
Brake Lights
I had the same thing happen once...they just stopped working.
After the normal bulb check, I found that the switch had just stuck. Lubed it up some and it's been fine since. It's located above the brake pedal assembly (no kidding) Take it out and free it up, should do it. |
SKINNY TIRES RULE!
VT - what did you lube the switch with? I looked under there this morning and it appears to be moving when I press the pedal - but it is still worth checking.
Switch
If memory serves...I cleaned it with WD-40 and lubed it with grease.(I think)
If you have a meter, just check it while it's out. It's simply a switch...make or break...check for contact. |
71 DELUX
ditto here,
I wrestled and stressed over the same symptoms for a while, thinking it was the rear harness, grounds etc... Turned out that the switch simply needed to be adjusted and it kinda works backwards. I took mine out, but left it plugged in and got myself in position to see whether or not messing with it would activate the lights. Sure enough, they were fine, very small area of adjustment for my switch, took 3 tries to get it working right with the pedal. good luck!
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
Franko72
your flat four probably has been spliced at one time for a trailer . just some loose connections ,or maybe some blown bulbs due to a short when ya washed it
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
SKINNY TIRES RULE!
Franko - what do you mean by "flat four"? I have a receiver hitch on my rig - very clean install on the wiring. What you are saying makes sense - they were working before pressure washing.
Franko72
the flat four is the standard wiring to most rear end brake, running lights , and turn signals. They are four wires That are all adjoined side to side in one strip. Seems to me that they were working before you pressure washed . did you wash under the rear bed? if so maybe you just disturbed a connection point to your wiring. have someone hold down the brake pedal while lightly pulling and tugging at some of the connection points at the wiring and see if the brake lights flicker. good luck.
#15 |
SKINNY TIRES RULE!
Yes, I did wash under the bed. I'll take a look at those connections first. It sounds like the most likely scenario.
This board is great! Thanks for all the help everyone!
