Old 07-15-2004, 02:28 PM   #1
72dually
72dually's Avatar
Unbelievable, bracket rivets broke
Im in the process of changing the 4.10 rearend in my 3/4 ton to a 3.54 I found in the boneyard yesterday, and I start to remove bracketry, and I notice the right shock mount to the frame has completely seperated, those big rivets have popped the heads off, and the front sway bar has 1 missing as well. I guess I'll just pop them out and replace with some grade 8 nut/bolt
72dually is offline   Reply With Quote
Old 07-15-2004, 06:20 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
That'll happen if they get rusty enough, or if there's a lot of stress on 'em.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-15-2004, 06:45 PM   #3
cdowns
cdowns's Avatar
that's why they call them old
Old 07-15-2004, 07:22 PM   #4
MOTHERTRUCKERS
I have the correct frame rivets if interested and can make you a tool to install them if you have a torch. Rivets 1.00 each, tool 30.00.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 07-15-2004, 09:05 PM   #5
crazy longhorn
Fabricate till you "puke"
A buck ea on the rivets & 30 on the tool....$36 is cheap on both sides I have 7/16 grade 8 bolts /pinch lock nuts on mine....shocks were moved back to stand em up after the drop. If you run grade 8 bolts, drill so they fit tight in the hole.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-15-2004, 10:09 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Grade 8s are okay, but overkill by a long shot. Shear strength on the steel rivets is close to a grade 2. I use grade 5 to replace rivets. And, yes, the hole needs to be a tight fit. I also don't mess with lock washers on those locations, red loctite works better.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-15-2004, 10:14 PM   #7
crazy longhorn
Agreed, locktite or pinchloc nuts.....lock washers are "tabu" on that stuff crazyL
Old 07-15-2004, 10:19 PM   #8
1972C10
1972C10's Avatar
I use metric bolts to put back in place of rivets I have found some that fit the hole when i put a front swaybar on 3/8 was too small for the hole and 7/16 was too big so i got a metric bolt and nut . I used some of those locking nuts
1972C10 is offline   Reply With Quote
Old 07-15-2004, 10:34 PM   #9
72dually
72dually's Avatar
Thanks guy's, I got some grade 8 serrated flange bolts with 10mm nyloc nuts, fit perfectly and cost me about $3 at the local home depot
Old 07-15-2004, 11:42 PM   #10
kwmech
I always touch the holes with a 'stepped drill' bit to get the holes round which ends up at 7/16. Grade 8 fine thread with grade 8 flat washers and a pinch nut.
