![]() Join Date: Dec 2003
What t-stat?
I have a big block with a 4 core and i was running a little hotter than normal today....100 plus heat though!! i have a 180 in there now and that is all that i have ever run and just recently did a flush and fill and used the premixed coolant so i know my mixture is right..so what temp t-stat do you guys use 160? or just the ol' 180 just currious.
https://www.ebay.com/itm/29620574751...mis&media=COPY |
I run a 180 in my 402. I have a 4 core, also. We've been up to 108 to 110 recently. I pull a 5500 lb trailer with my truck and very seldom see it over 200, usually 190ish, up a little while pulling up hill. I'm not concerned about 200 (or 210 for that matter) as new stuff runs that hot all the time.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
once the motor warms up to operating temp it's going to run the same temp with a 180 or 160 thermo. thermostats don't have a refrigeration system built into them
Fabricate till you "puke"
A BB will run a little warmer than the run of the mill sb. I run a 180 stat in my 383, & it stays pretty constant on temp(tween 180-190). I ran a BB Olds in the truck, with the same 4 row core (fresh rad)....that one ran a 160 stat, & generally ran 210 in traffic on a 95 degree day. she would cool down to 175 rollin down the road tho.... I agree that 210 is no big problem.....you start pushing 225-230 & I get a little nervous
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
