07-19-2004, 12:51 AM | #1 |
truck is all fixed still problems
i just did a transmission, transfer case, front axle and rear axle swap and it all went good. except my speedo is way way off i had it pegged out at 100 and it felt like 50 or 60 ish. that is with tires that are only about 30 inches when i put the 33's back on it should be closer but not exact. the 2nd problem really bothers me. somehow my steering wheel is upside down. i have full turning abilitys and it drives straight and everything. can i pop the steering wheel off and put it on straight or do i have to go under there again and tighten this and loosen that. how hard is it to take off the steering wheel? is it splined to go on only 1 way?
i have to fix the steering wheel i cant stand it. as for the speedo can i put in a different box thing off another transfer case to fix that or what? thanks stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
07-19-2004, 01:03 AM | #2 |
You can rotate the wheel at the rag joint 180 degrees I believe. Couple of bolts.
07-19-2004, 02:33 AM | #3 |
user # 2756
stan what gears did you have? Sounds like 3.08s you would have been off by about 50%. Agree with Randy easier to rotate at the rag joint. But with a good puller the steering wheels do come off easy. Your going to want something taller than 33s. I'm running 35s w/ 4.56s and top out at about 60 on the highway.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-19-2004, 10:10 AM | #4 |
yep it was 3.08
with 4.56 its like a whole new truck. i know i need bigger tires but that means i need lift as well. im looking at some 36x13.50 iroks, and a 4 inch lift when the money gets right. its more of a toy than a daily driver so im not worried about gas milage. i get more smiles a gallon now. thanks ill try the rag joint that does sound easier i dont know why i didnt think of it.
thanks stan
07-19-2004, 10:13 AM | #5 |
With 4.56's the 36" tires will be a lot more friendly. I'm running 35's and I have 4.10's and its just about right.
07-19-2004, 11:15 PM | #6 |
Mudder67
that rag joint was the way to do it. it took about 10 minutes and now my steering wheel is pretty straight its a little off but i can live with it. now all i need is a 4 inch suspension lift and some 35x15 boggers for 100 or less and im in.
thanks stan
07-19-2004, 11:19 PM | #7 |
daughters b/f has some 16.5x35 boggers for sale but not sure what hes asking.
