Old 07-19-2004, 02:18 AM   #1
aliencheyenne
Cool help leveling out a 3/4 ton
I just want the rear and front to sit level on a 73 C20 2wd. Are lowering blocks or drop shackles in the rear my best bet and are their kits out there for 14 bolt FF ? What about lifting the front end 2" or so ? Also, with the driveshaft setup on the truck, would I run into any pinion angle problems ? Thanks
aliencheyenne is offline   Reply With Quote
Old 07-19-2004, 05:53 AM   #2
Nvbowtie
Nvbowtie's Avatar
I may be wrong here, but I would say you could either pull a leaf or two from the rear or
Coil spacers, not the twist in's, get the spacer for the bottom of the coil.
http://www.jcwhitney.com/autoparts/P...X/appId-385802
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
