FUEL CELL GURU
Need rearend for 4WD to 2WD conversion....
Anyone have a 71-72 GMC five-lug rear?? I just think this should be a swap-in for a leaf sprung 4WD rear. Will a 73-up rear fit?? Later, FCG
faster, faster, faster
Hey FCG, you better check local inspection laws about converting a 4wd to a 2wd. A converted rig is illegal to inspect here in Texas.
I'm going to Law School, wanna debate? It's good practice. |
A 2wd leaf spring has the spring perches in a different location than the 4 wd spring perches.
Jim |
FUEL CELL GURU
I am not worried about the inspection as when it is registered as an antique, no inspection is required. Jim, are you sure?? Are they wider or narrower?? I am confused.
Smonty
Hey Mark,
If you need one with a higher gear ratio I have a good 2wd leaf spring axle off a 72 GMC. If you find out you can use it we can work something out towards what I owe you for the wheels. Ernie
72 2WD Blazer 68 SWB Fleetside 67 SWB Stepside 2005 Chevy 1500HD Crewcab 56 Chris Craft Mahogany Runabout Looking for 36 Chevy 1/2 Ton P/U Project |
FUEL CELL GURU
Ernie,
Can you measure outside to outside on the spring perches?? Is it 5-lug?? Later, Mark |
