07-22-2004, 11:40 AM | #1 |
It followed me home?
t-case drop
What do I need to drop my t-case? I realize I need some longer bolts but what do I use to space it? and do I need a special grade bolt, or will some bolts from home depot work? 1" is the most I should drop it right? Thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-22-2004, 11:42 AM | #2 |
i just used the stock spacers and bolts that were in there already. about 1" long. Remeber to check that tranny mount too
http://members.cardomain.com/chevyjeff 57 2 DOOR HDTP 82 CORVETTE 90 V10 BLAZER 97 REGAL LSR 2100 (BOAT) |
07-22-2004, 11:46 AM | #3 | |
Oh and the tranny mount is good, the tranny is slipping though. Time for a 700r I guess.
07-22-2004, 12:01 PM | #4 |
try this it has the info on tc drop and the grinding of the front shaft cv joint which you will neeed to do also
http://rough.roughcountry.com/145S.pdf
07-22-2004, 12:09 PM | #5 | |
great info, thanks
07-22-2004, 02:33 PM | #6 | |
How long did all this take you?
07-22-2004, 04:37 PM | #7 |
I can tell ya I dropped the one on my '86 blazer.. used pipe fittings for spacers 1".. never needed to grind the cv on the front driveline..
I will however hint around to sandwiching the frame where the bolts go through. I started to crack my frame from flexing and torque.. so I took steel plates 1/4 or so and sandwiched the frame ..then just tackweled them in place.. never had a problem since..
Support The Board |
