Largest Tire Size Without Modifications
Hello Guys:
What is the largest tire size (millimeters or inches) in height and width can I use with and 18" wheel on my 1972 fleetside chevy if I lowered it 2.5 inches in the front and 3 inches in the rear. I like the look of a 285/50 R18 ( 11.2' wide and 29.2" tall) for the rear and a 255/55 R18 (10" wide and 29" tall) for the front. I sure don't want my tires to scrub ![]() Thanks Guys |
this would be very good to know - I want to do the same thing on my '70
I like the 25.5X 10 " on all 4 corners!
I also like to go 185kph!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Certified Chevy Man
The size you are thinking of will work, the 285/50s and 255/55s. I was gonna run those on mine lowered 3/5. I'm going to 20's now that are right at 30" tall and 11" wide. The tires on it now are 30" tall and 11" wide, no rubbing, no problems.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff 71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score Check out my web site!!! http://www.geocities.com/cst68chevy/ |
Dam 30" tall w/no rubbing?
what's the backspacing and lowering to get 30" tire?
Certified Chevy Man
They are 15x7's with 3.5" backspacing. I actually was pushing it around on 33's on 15x10's with 3.5" backspacing with a 3/5 drop. The tires I wanta run are 275/45 or 295/40 20's on 20x9 or 20x9.5's with 4-4.5" backspacing and I don't see a problem. Nothing looks cooler than FILLED wheel wells on a lowered truck. As for the drop, I've got about 1.5" till I hit bumpstops on the front and 2" on the back.
