Which is the more preferred method to drop rear of 73-87 C-10 in conjunction with flip kit to attain a 6 " drop, a 1 inch lowering block or use of a drop shackle? Reason?
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
You get what you pay for
![]() Join Date: Dec 1999
Shackle. Blocks are bad IMO.
Mike 1985 Chevy C-10 |
Under construction!
I agree w/ Mike. Shackles are the way to go.
2001 Silverado bagged on 22's. *Sold* |
Thanks for the input and advice.
www.73-87chevytrucks.com
Getting in this late, but I agree. Blocks are not a good idea in my opinion.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
A 1 inch block would not be bad even a 2 but blocks do tend to make spring wrap worse. The problem with the shackles is they may throw off your pinion angle but even that's mute point since your doing a spring under. Your going to have to do new spring purch anyway. If your going big HP do the shackle for sure but otherwise...what ever is cheape just make sure the block is solid STEEL. www.offroaddesign.com sells a 1 inch block that also lest you move the axle forward and back if your having problems with the wheel not centered in the wheel well.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
