07-31-2004, 08:18 PM | #1 |
Taking Off The Cab: This easy??
I'm going to be taking off my cab pretty soon, to paint it the RIGHT way. Is it this easy though?
1.) Unhook shift linkage 2.) Unhook Steering Column Shaft 3.) Unplug wiring harness 4.) Unhook Heater Core 5.) Remove doors 6.) Remove the 4 Cab Mount Bolts 7.) Use CherryPicker with straps to lift cab off frame Is that about it? Doesn't seem very hard, for a good payoff (Completely same color cab) |
07-31-2004, 08:37 PM | #2 |
Don't forget to unhook the throttle cable, washer hose, unbolt the front fenders, speedo cable, vacume hose to air control, unbolt brake booster/master cylinder.. All the things on the firewall which also connect to the frame/engine.
07-31-2004, 09:44 PM | #3 |
california fill
I dunno about the cherry picker idea.. It will probably be easier to just get some guys to help you lift it off (4 guys total will be perfect)... but make sure you have a place to set it! on blocks is nice.
pc |
07-31-2004, 11:00 PM | #4 |
yeller
Take the seat out to make it lighter. Also, don't forget the E-barke cable and engine ground strap (if you have one connected to the firewall). Make sure to drain the brake fluid from the master cylinder resevoir, otherwise it will make a mess.
You are going thru A LOT of work just to paint the cab one color.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-31-2004, 10:58 PM | #5 |
Under construction!
I have removed two cabs and it's fairly simple. As mentioned before, having 4-people to lift the cab off would be ideal.
2001 Silverado bagged on 22's. *Sold* |
08-01-2004, 02:05 AM | #6 |
i removed mine myself. i put 4x4s under the rockers and jackstands on blocks under that. just jack it up a little at a time, and set it down the same way. i left mine intact. AC, seat, doors, just unhooked everything.
08-01-2004, 07:14 AM | #7 |
I don't have a windshield wiper motor anymore. I'm going to leave the master cylinder on the firewall, just plug the holes (where the lines connect).
Yeah, it might SEEM like a lot of work, but in the end, I'll be able to pop my hood and not feel stupid that the firewall is a different color. |
08-01-2004, 05:20 PM | #8 | |
and I painted the fenders below the hood line and matched up to the cowl weatherstrip line for a break to yellow, I dont feel stupid. Unless your going full blown show, I dont think you need to pull the cab, just my 02 cents. |
08-01-2004, 08:32 PM | #9 | |
08-01-2004, 08:33 PM | #10 |
Seems like yanking the motor would be easier than pulling the cab off.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
08-02-2004, 05:26 AM | #11 | |
my entire front end was off, but you could still paint the firewall for daily driver quality. All mine consists of is, I scraped and sanded the firewall, sprayed it with self leveling undercoat for a smooth finish and painted the the inner fenders the same, except I put on duplicolor black gloss then a coat of clear on that. Last edited by Nvbowtie; 08-02-2004 at 05:29 AM. |
