08-09-2004, 01:52 PM | #1 |
question for all you guys with air bags
Hey all you guys with air bags, who here has a good set up that they put together the cheapest? any body go with manual fill? If so how much?
63 c-10 shortbed fleetside |
08-09-2004, 05:20 PM | #2 |
Read up . . .....
08-09-2004, 08:23 PM | #3 | |
Seņor Member
But it's easier to just ask the same questions over and over than to use the search function
08-10-2004, 07:41 AM | #4 |
Hey GarageGhoul is a new guy and this website is his first forum - he may not even know about searching old posts yet.
I know I'm not entirely sure how to search the forums here at 67-72trucks. -W |
08-10-2004, 10:04 AM | #5 |
True... the current set-up does not promote the use of searchs. But, it's pretty easy to sit back & read thru @ least the last month worth of posts in each forum to check threads w/similar content.
I'm no web veteran, but of the boards I do frequent, when I was new I would lurk around & read as much as possible before asking questions because alot of people are sensitive to repetitive questions. Glad to have new guys around.... welcome to the board.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-10-2004 at 10:37 AM. |
08-10-2004, 11:04 AM | #6 |
More Cowbell....
Our search function seems to be MIA anyway.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
08-10-2004, 04:36 PM | #7 |
Actualy I have used the search and read all the results, Ive tried to use it recently and it's not working. ]AND I have read through almost all the suspension threads on here but I still had some questions. You know with sarcastic remarks such as the one made by XXL, I almost want to go back to just lurking. Finaly got the guts to post and this is the response I get? Do yo consider that helpfull? by the way thank you Woogeroo and SCOTI. I have read up alot more than some people suspect and SCOTI, your threads have been very helpful in the past.
08-10-2004, 04:51 PM | #8 |
Glad to be of assistance. Don't let the short fuse of some alienate back to lurking. XXl does come across bitter @ times but does offer alot to the board as well & I welcome him too.
08-11-2004, 02:12 PM | #9 | |
Seņor Member
08-11-2004, 05:36 AM | #10 |
Ok - no searchy action. I thought maybe I was going nuts.
-W |
