![]() Join Date: May 2004
Rearend
I have one more question. I would like to swap the rear out of my truck for a 12-bolt from 67-72. I have a '69 3/4ton 2wd Burb with an Eaton Rear & coil spring suspension. Will a 12-bolt with a coil spring suspension bolt right up w/o a problem?? Are the dimensions close enough for the driveshaft to work w/o being shortened or made longer?? What about the brake lines and Emergency Brake Cables?? Thanks for the help...Chris
its all about the +6 inches
I think it'll pretty much bolt in, but you may have issues with brake line size/location...and the U-joint will most likely be an issue too.
