Starter and exhaust pipe distance
With a stock setup of 2 inch pipe coming from a ramhorn exhaust manifold that is angled down. How far is the pipe supposed to be from the starter?
Thanks |
Forgot to add. How far is the exhaust pipe supposed to come down from the exhaust manifold before it straightens out and goes toward the end of the truck.
Thanks |
Ttt
Ttt
I am not sure on rams horns, I have hedman headers and mine are VERY close 3/4" and I have to have a heat shield installed and a mini starter.
Man I need another 67-72!!! ![]() |
Designated A-hole!
If it's not raining I will check and try to get a pic of mine when I get home.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Thanks Krue, I appreciate it.
Fabricate till you "puke"
I have Hookers, & 1 tube is within 1/8 " of the starter.....doesnt cause a bit of problem here in the midwest with 95- 100 degree temps
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Designated A-hole!
Here's what I came up with. I have ramhorn manifolds and what I assume is the stock y-pipe.
Thats about the distance I have on mine but its not a y I have duals.
Thanks Krue I apprecaite the pics. |
