<<< R 67 PROJECT
Need a link for interchangeable parts for 69-72 2wd blzr / 67-72 pickup
have 68 clip-70 2wd frame-tub??? what yr. would be best? thanks
NEW BABY!!! '67 STEPSIDE FRAME OFF PROJECT bullstowin40@sbcglobal.net -92 2wd burb 225k dailey driver -98 nissan quest the wifes -67 C-10 stepside my toy |
Mike
Look for a 71 or newer front suspension,that way you have discs up front.A 2wd blazer with a 68 front clip looks good.T he front suspension can be from 73 up.You only need to drill 2 holes to get the new crossmember to fit.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires Last edited by smokekiki; 08-17-2004 at 11:25 AM. |
#3 | |
<<< R 67 PROJECT
![]() Quote:
![]() Join Date: Jun 2002
All the tubs will work from 69-72, best one to use is the best one you can find (little rust), regardless of year. I also prefer the 71-72 frame due to the front disc and 5 on 5 bolt pattern. As far as using the 68 front end you would need the hood, front fenders radiator support and the grill.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#5 | |
<<< R 67 PROJECT
![]() Quote:
is there a link or a manuel on interchanges?
Mike
Don't know of any links,but like raggedjim said,You need the fenders,hood grill,hood latch,rad support,and support cushions to put the 67-68 front sheetmetal on.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
