Old 08-20-2004, 07:17 PM   #1
mudgutsandglory
Certified Truck Nut
mudgutsandglory's Avatar
rear coil removal
do i need a spring compressor to remove my rear coils?? i was thinking i dont, that i can just jack the frame up until the springs reach the end of their travel, then just support the rear end with jackstands and remove the coils. im not sure and KNOW better than to monkey with coil springs without being sure. when i was in school i watched a coil spring cross a shop and a busy street becaue it wasnt securely in the spring compressor while a strut was being dissasembled.
I will be swapping in a set of springs a buddy of mine gave me, he is restoring his chevelle and ordered new stock springs, but then decided to use station wagon springs instead, so he gave me a brand new pair of springs for free. i figure i may as well try em, of course this will be temporary until i can afford a good kit from Early Classic. right now im just trying to get the truck presentable so i can cruise alittle before the end of summer.
thanks in advance
1982 GMC Sierra Classic 1500 Longbed
350, TH350, 3.73 10 bolt
soon to be slammed
mudgutsandglory is offline   Reply With Quote
Old 08-20-2004, 07:39 PM   #2
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Just lift up the rear end untill the tires are off the ground and put jack stands under the FRAME. Then use the jack to releave the tension in the rear springs which there isnt much anyways. Then it is a simple removal of 2 bolt for each coil.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 08-21-2004, 10:59 AM   #3
69ride
All Go, No Show
69ride's Avatar
exactly what disturbed said
69 LWB
Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI.
69ride is offline   Reply With Quote
Old 08-21-2004, 11:52 AM   #4
Shane
Shane's Avatar
jack the truck up ... secure frame on jackstands ... break bolts loose ... laff at the funny sound a coil spring makes when it hits the concrete floor.
Shane is offline   Reply With Quote
