08-21-2004, 04:39 PM | #1 |
What I drive
Pics of a swb with a 2/4 drop?
Wanna see what it looks like as that is probably the combo I will use when I get around to it. Thanks
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
08-21-2004, 05:34 PM | #2 |
You get what you pay for
I'm pretty sure this was when I had my truck at 2/4, with stock 8" ralleys and 275/60R15's. Anyway, it's been several years but I think I'm right.
Mike 1985 Chevy C-10 |
09-07-2020, 01:43 AM | #3 | |
Re: Pics of a swb with a 2/4 drop?
How that’s interesting how his 2in front is lower than mine and I have 3in belltech spindles. I have a way bigger fender gap. These are 255/60/15 so they 27in. |
08-21-2004, 06:39 PM | #4 |
Stepsides RULE
yeah 2/4 is the way to go as long as you're not ghettoing things out. im gonna spring for 2/4 eventually, when $$$ is rolling better.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
08-21-2004, 08:22 PM | #5 | |
What I drive
08-22-2004, 12:04 AM | #6 |
No, you'll be fine. Your tires are 29" and the 275's I had were 28. 2/4 is by no means a drastic drop. There is plenty of tire clearance. 2/4 is not ghetto but I guess my 4/6 is.
08-25-2004, 08:12 AM | #7 | |
Garage Queen Material
CHILL OUT MIKE!!! i believe he was trying to say, that as long as you drop something the rightway(with good parts) its not ghetto |
08-22-2004, 07:23 PM | #8 |
Stepsides RULE
lol good deal, ghetto can work, but i don't like it I'm going for 15x8s up front and 15x10s out back, with the Eagle series 054 wheels. www.eaglewheels.com
08-23-2004, 09:17 PM | #9 |
BAD BOW-Silverado XST
245/60R15 front 255/60R15 on the rear. 2.5 spindal and 4" hanger/shackel combo. |
08-24-2004, 05:24 AM | #10 |
Front- 2.5 front spindle drop 235/60/15
Rear - 4.0 rear drop spring 255/60/15 |
08-24-2004, 04:22 PM | #11 |
3" drop springs front
5" rear flip kit 255/60/17 on 17x9's
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
08-24-2004, 11:29 PM | #12 |
Looking @ 67 Chevy Short Step
Which combo is cheepest? 3" drop springs front, 5" rear flip kit
or Rear - 4.0 rear drop spring, 2.5 front spindle drop or 2.5 spindal and 4" hanger/shackel combo. Im new to the truck scene and i have a 82 short wide, 1/2 ton. Thanks |
08-25-2004, 08:07 AM | #13 |
I think my 2.5 spindle 4 shackle/hanger was $350 shipped from sport truck direct. I'm not too sure though b/c that was a long time ago.
Here it is as a fleetside long bed: And as it is now, Stepside short bed (yes its the same truck!) The front looks higher b/c the motor is out:
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
01-20-2005, 06:05 PM | #14 |
*Proud Member*
through a board search, i am resurrecting this thread! I currently have a 2000 s10 as my daily driver that is slammed! i have a 3/4 drop on my xtreme and my front end is about 1.5" from the ground... i did this with 2" spindles and 3" blocks in the rear....
my question is with our 73-87's how do you acheive a 2/4 drop... from this post, i see most all with a spindle up front... and either a flip kit, drop springs, or hanger/shackles in the rear??? so, i'm stumped! also, someone had a great post up about lowering before with part numbers and costs, ect... where'd it go!!! i can't find it! |
01-20-2005, 06:33 PM | #15 |
Hotwheels?
2/4 isnt much of a drop, you'll prolly want more later. Get a spindle for the front though, because its the easiest that way to just add springs to.
The rear, get some shackles and hangers, but keep the stock stuff if you want to put it back on to go lower later with a flip kit.
1978 Money Pit - CUSTOM DELUXE!!!! |
01-20-2005, 07:15 PM | #16 | |
01-20-2005, 06:35 PM | #17 |
Insert Witty Text Here
Front spindles can get you a 2.5 or 3 inch drop in the front. You could also go with drop springs, but you lose some suspension travel.
On the back, you can get 4 inches with hangers and shackles. You can also go with 4 inch drop springs. A flip kit would get you 5 to 6 inches of drop, I think. Slonaker |
09-07-2020, 03:51 PM | #18 |
What engine do you have in that? Engine selection can play a role in front end height. Even swapping from cast iron heads and intake to aluminum pieces drops weight big time.
09-07-2020, 04:04 PM | #19 | |
I got a 454 baby! With long tube headers so I like that it clears them now with these new springs but the drop before it was way better! But I didn’t like hitting the headers on high speed ups . Look how bad it tucked those 255/60s. But it was just too bouncy. And crazy that the new springs and the old ones where the same Height. Had no idea that it was going to lift up that much like a 4x4 Posted via Mobile Device |
09-07-2020, 04:35 PM | #20 |
And it’s pretty much leveled now with the back being 29 and 1/4in And the front being 29 and 3/4in almost 30in. So they are pretty much same height and the back I have just a drop shackle. I don’t think they make 4in shackle so I guess it’s just a 3in. I plan on just getting a belltech drop shackle and hanger for the a real 4in drop and maybe cut a coil or .5 of a coil for that fine tuning and have it dialed at the same height
09-07-2020, 04:58 PM | #21 |
Wow, I expected to hear small block with aluminum top end or and LS swap. That’s some pretty tall ride height with a big block!
Edit: If those are new springs on there and your old ones were too bouncy, it may be beneficial to you in more than one way to cut a bit out of those new springs. One, you can get back to the ride height you were at before, and two, since you’ve cut a coil, you’ve increased the spring rate over stock, so they’ll be more resistant to bottoming out at the same height. |
09-07-2020, 05:55 PM | #22 | |
09-08-2020, 09:44 AM | #23 |
Be patient.The front will settle down a bit over time. It might settle as much as in inch. 255-70's would close the gap up also.
09-08-2020, 11:53 AM | #24 |
09-08-2020, 11:48 PM | #25 |
I've been thinking about doing a 2/4 drop on mine. Only reason why, I had a stroke 3 years ago and it'd be easier for me to set down in. 255/70-15 all the way around plus I'm putting the camper shell back on. My go 10" wheels on it instead of 8's
