Old 04-04-2002, 11:03 PM   #1
Brian19692
Post Locker
Anyone running a locker? I am getting ready to rebuild my 12 bolt and I'm thinking about going with a locker. I was wondering about how they act on the street. Thanks.
69 short box 4x4
72 long box
69 Camaro 327 4-speed
71 4x4 suburban, soon to be crew cab short box
87 S-10 V-8 FOR SALE
Des Moines, Iowa
67 short 2wd. FOR SALE
69 long box w/72 grill
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
Old 04-05-2002, 12:42 AM   #2
Alexis
Member since 2000
Alexis's Avatar
Post
your tires are going to bark on turns.
Mechanic @ California Concept
Britney: 1970 2wd K/5 Blazer (Frame up)
Jessica: 1967 2wd SWB (pops daily driver)
Helga: 1972 4x4 3/4ton LWB (my daily driver)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
Old 04-05-2002, 07:27 AM   #3
VNMOUS
Step Side's Rule
Post
I'M RUNNING 3:08'S WITH AN EATON LOCKER. IT DOES BARK ON TURNS BUT, I LIKE THE BITE I GET WHEN I LEAVE OUT !!!!! THE TRUCK SEEMS TO RUN STRAIGHT ON THE ROAD NO DRIFTING TO THE SIDES.
DANO
67shortstep:350/350,flows,headers,3:08posi,edel intake & carb
76 stingray
95 cobra
IBEW 558
DANO
07 Silverado Classic
67shortstep
76 stingray
95 cobra
66 Mustang Coupe 289
VNMOUS is offline   Reply With Quote
Old 04-05-2002, 10:08 AM   #4
Yukon Jack
Yukon Jack's Avatar
Post
Mine has a Detroit Locker in the rear Eaton axle. I'm very pleased with it's on highway manners. Every once in a while I get a big clunking noise and it does pull a little when initially accelerating on the highway, but other than that it is not really noticeable.
I don't get chirping when I turn slowly and I've heard they can be problems on ice and snow, but I have had no problems yet.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-05-2002, 01:49 PM   #5
COBALT
COBALT's Avatar
Post
I have a detroit locker in my stock 3/4 ton Corp. axle (HO52?) with 3.90 gears. I simply love it.
It helps if you have a LWB. It clunks loudly when I'm pulling away from curbs after the truck has sat for a while, and there's noticeable play in the driveline (clunk on accel/decel), but I love the stability while I'm driving around.
Around corners I don't really hear anything, but I do feel some slippage on the inside wheel just as I'm straightening out (when the inside wheel locks back into place), so don't expect to do any "Starski & Hutch" moves around corners and have it look cool for the cameras! hehe
We had a random snow in early March in Seattle. I was coming back from the tire store, and I live on a hill so I was cruising down it toward my house. I did loose some traction, and it was difficult to feather the accelerator to keep the tires from spinning, but a little planning, and some cool nerves kept me from banging into anyone. Funny there were 4 fender-benders right in front of my house. All were SUV's! lol
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 04-05-2002, 06:12 PM   #6
Brian19692
Post
Thanks for the replies. I was worried about pulling a trailer with one. But it sounds like all the magazine warnings about curves and turning shouldn't be a problem.
69 short box 4x4
72 long box
Des Moines, Iowa
Des Moines, Iowa
Old 04-05-2002, 09:23 PM   #7
JReynolds
Post
I have a Powertrax Lock-rite in my 12 bolt 3.08 rearend. I am running a Saginaw 4 speed with 380 horse/450 ft/lb torque. When I am going hard through the gears, but have not broken traction, it will lurch to one side or another. It does this because unless the locker "thinks" it needs to send power to both wheels, it will only send it to one side. But if I burnout at all, it will not sway. The little bit of "clunking" noise going around sharp corners at slow speeds is pretty much muted by my exhaust. I like this unit because it was $300.00, easy to install, and didn't have to tough ring & pinion settings. I will say, that for a daily driver, probably a true posi unit would be a better choice. My truck is strictly for pleasure, with occasional trips to Epping Raceway for timeslips. Hope this helps.
1969 SWB Stepside. 350 w/Vortec heads, 380 H.P., 450 ft/lb dyno proven.
JReynolds is offline   Reply With Quote
Old 04-05-2002, 09:53 PM   #8
Scrub
Collector of rusty Items
Scrub's Avatar
Post
I put a locker in my Corp-14 and I had to take it because it was unsafe to drive. I live in Central Oregon and we get a lot of snow and ice. I was in every ditch in town. If you don't have snow, it would probably be great. Personally I would like an ARB air locker, or the new Eaton electric locker that is better that the ARB because you don't need air. Both are better than a Detroit because you can turn them off.
http://www.torquecontrol.eaton.com/prod1.htm
http://www.rockcrawler.com/techrepor...view/index.asp
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
