08-25-2004, 08:20 PM | #1 |
Franko72
Fiber optic Question
Was the Fiber optic light for the shift indicator installed on all 67 - 72 years or was it an option?
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
08-25-2004, 09:03 PM | #2 |
huh?
I believe it was standard on any auto 67-72, but I could be mistaken. TTT for you.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
08-25-2004, 09:44 PM | #3 |
My tilt column uses a small light bulb
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
08-25-2004, 10:38 PM | #4 |
its all about the +6 inches
In non-tilt automatic columns, the fiber optic cable was standard issue.
As stated, tilts got light bulbs. |
11-07-2004, 09:00 PM | #5 |
Where does the fiber optic cable connect for a light source? Mine appears to be broken off. Does anyone know where I can get a replacement?
11-07-2004, 09:07 PM | #6 |
67-72 Addict!
I know the fiber optic attaches to the socket closest to the speedo just like the little 194 bulbs. I don't know if it uses a 194 bulb or different type. Does anybody know the bulb number?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-07-2004, 09:08 PM | #7 |
It goes to the rear of the cluster. Near the upper center I believe. it is just a little pin that slides into a tab.
11-07-2004, 09:13 PM | #8 |
a 194 is the correct bulb.
11-07-2004, 09:29 PM | #9 |
67-72 Addict!
I was hoping the fiber optic bulb was different because I tried a 194 in it and it didn't work. Andy, the funny thing is I bought a replacemnet fiber optic assembly with bulb from you 2 years ago and I can't find the damn thing!
11-07-2004, 10:21 PM | #10 | |
Cantankerous Geezer
Fred There is no such thing as too much cam...just not enough engine. |
11-07-2004, 10:20 PM | #11 |
LOL...that is funny.
you wanna buy another one? (J/K...I don't have any right now) |
11-07-2004, 10:26 PM | #12 |
If your original fiber shift indicator seems a little dim you can brighten it up just a little by trimming a few thousandths off the cable ends (fiber optic) with a new razor blade, be sure to make a straight clean cut.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
11-08-2004, 08:39 AM | #13 |
67-72 Addict!
Fred, I'm putting my dad's truck back together after a recent paint job. It's been off the road for over a year. I have been buying tons of parts for the last 5 years and I can finally see the light at the end of the tunnel. I just wish it was FIBER OPTIC,LOL!
11-08-2004, 03:55 PM | #14 |
Be carefull...the last light at the end of a tunnel I saw was a huge gorrlia with a mag light!
