Old 08-26-2004, 01:45 PM   #1
ScottH
ScottH's Avatar
Can a SBC power steering setup be used on a BBC?
Hey guys,
I have 68 project truck I plan to install a 396 in it. I have a power steering setup for a small block and was wondering if I could use it on the big block. I'm not too concerned about originality right now, maybe later but this would save some cash for the time being.
Any info or suggestions would be appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 08-26-2004, 04:08 PM   #2
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The pump istelf, gear box, and possibly even the lines will work but the brackets will be different I beleive. Chevy used the same pump and gearbox on all the trucks, actually the pump is probably swappable to any GM car or truck up to 79 when they switched to the metric O-ringed hose connections. The return hose is no big deal, just shorten the one you have or get a new piece if you need a longer one. The pressure hose may work depending on the position the pump will be compared to the small block. Get some PS brackets at a junkyard or from one of the many good vendors/members on here.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 08-26-2004, 04:23 PM   #3
GMC AMI
GMC AMI's Avatar
Brackets are not the same.
As 72 said, the brackets are not the same , the block holes are spaced dif. on the small block vs. the big block. If I rem. the big block holes are wider spaced and are Dif brackets.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 08-26-2004, 05:23 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The pump housings are way different too, as well as the brackets already mentioned.
The big block uses a big hose leading to a remote fluid reservoir on the fenderwell.
The small block has the reservoir built into the pump itself.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-26-2004, 06:38 PM   #5
tom hand
CCRider
tom hand's Avatar
You can use the pump you have now with an alan grove bracket and the short waterpump...if using a long waterpump just use 73 up brackets
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-26-2004, 07:53 PM   #6
ScottH
ScottH's Avatar
Thanks guys, just what I was looking for!
Old 08-26-2004, 08:21 PM   #7
flip66
flip66's Avatar
I have a 69 396 and I used the alan grove bracket works great
flip66 is offline   Reply With Quote
Old 08-26-2004, 10:02 PM   #8
ScottH
ScottH's Avatar
Flip66, did u use a short or long wp? If short, how did u mount the alternator?
Thanks.
Scott
Old 08-26-2004, 11:44 PM   #9
flip66
flip66's Avatar
Pic
It had the short water pump and the alternator bracket on it when I got it. The power steering box was there but someone had removed the power steering pump and bracket so I know it had one. I did not want to pay the 200.00 for the factory one so I bought the one from alan grove for 60.00 and used the pump I had. I have attached pictures
Old 08-27-2004, 03:01 PM   #10
72C203503ONTHETREE
Cool, learned another thing today, I never saw an older(pre 73) big block truck so now I know the pumps are different also.
