Old 08-29-2004, 01:10 AM   #1
duke10
Active Member
duke10's Avatar
Headlights are out
I have a 72 gmc short bed and the headlights don't go on. Taillights, dash lights and running lights are all okay. I am not real mechanical and was wondering if someone could give me the basics of troubleshooting this problem. By the way the high beams haven't worked since I purchased the truck 18 months ago. Thanks
duke10 is offline   Reply With Quote
Old 08-29-2004, 01:17 AM   #2
tmcgrawlookalike
check your dimmer switch.replacement is about 5 dollars at a parts store.sorry,but i don`t recommend auto zone crap.hope this helps
tmcgrawlookalike is offline   Reply With Quote
Old 08-29-2004, 06:53 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I agree on the dimmer switch. To test, unplug the wiring harness from it and use a jumper wire. It should have 3 wires and one will have power. Jump that one to either of the other 2. If it's a bad switch or dirty connections, lights should work. Jump to the other terminal and again lights should work. One will be lows and the other will be highs.
Often times it's just dirty connections though.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-29-2004, 06:57 PM   #4
duke10
Active Member
duke10's Avatar
Thanks guys
Old 08-30-2004, 02:54 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Be sure to also check the ground leads from the ends of the headlight harness to the radiator wall. One each left and right. The 4-eyed set-up is a little more prone to bad grounding than the 2 headlights of a Chevy. (I have a '71 Jimmy, too) Sand or file any corrosion from the terminal ends and around the screwhole and re-attach.
Old 09-02-2004, 02:12 PM   #6
duke10
Active Member
duke10's Avatar
great info, thanks
