09-01-2004, 11:20 PM | #1 |
uneven rear springs ?
I have new 4" drop springs in my 67 SWB, one side of the bed is 3/4" higher than the other. I would like the higher side to match the other. How can I fix this ? I was thinking about clamping a couple of coils together to lower it. Anybody done this? I have seen spacers for raising them but have never seen clamps for doing this. Thanks for the help
09-01-2004, 11:23 PM | #2 |
Got Light Emitting Diode?
like a small ubolt with a bar across and nutz to tighten it down? thats what i have pictured
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
09-01-2004, 11:26 PM | #3 |
Thats what I'm thinking also, has to be the springs making it uneven, nothing else there.
09-02-2004, 12:21 AM | #4 |
Before and After
Be sure to check the frame Height, I had the same problem, and it turned out to be the crossmembers of the box were our of whack, I ended up changing those to correct the Droop in the one side.
Good luck.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
09-02-2004, 09:08 AM | #5 |
I'll do that, How was your crossmember out of whack ?
